Question Hide Images and Attachments for guests..
16 years 10 months ago #20248 by skkuumar
hi roland
will this hack work for Kunena 1.5.3?
regards
skkuumar
16 years 10 months ago #20316 by 810
yes, it's still workig for kunena 1.5.3.
just copy the lines and its working perfect
16 years 10 months ago #20851 by alakentu
Does not work in 1.5.3, at least not to me, will not let me see the attachment, tested on localhost. :(
KS!
NO hacer Spam | NO esbribas todo en mayúsculas | Sigue las reglas
16 years 10 months ago #20877 by 810
try this package:
download
16 years 10 months ago - 16 years 10 months ago #20925 by alakentu
810 wrote:
try this package:
download
Thank you for the trouble you've taken, but still does not work for me, that does not recognize this or not the user logged on, never shows the image file or aggregate, are not taken from configuration data that have been established.
Thanks anyway, wait to see if we can resolve in other versions of the hack.
Thank you all.
Edit Date 26/06/2009
Testing the different configurations of the code I have with what would be a total correction for the complete operation within Kunene 1.5.3 (at least in association mic works) all the code in the files:
administrator/components/com_kunena/admin.kunena.html.php
administrator/components/com_kunena/admin.kunena.php
components/com_kunena/lib/kunena.config.class.php
Remain the same and without any changes, edit the file with a new code
components/com_kunena/lib/kunena.parser.php
Around the line #338 located code case 'img':
case 'img': if($between) { // rolandshack start if ($my->id==0 && $GLOBALS["fbConfig"]->showimgforguest==0) {
The change in this code:
case 'img': if($between) { // rolandshack start if ($kunena_my->id==0 && $fbConfig->showimgforguest==0) {
Around the line #380 located code case 'file':
case 'file': if($between) { // rolandshack start if ($my->id==0 && $GLOBALS["fbConfig"]->showfileforguest==0) {
case 'file': if($between) { // rolandshack start if ($kunena_my->id==0 && $fbConfig->showfileforguest==0) {
Using the original codification of the new kunena 1.5.3 work on my localhost site and well, I hope to serve you.
EDIT: REMOVED ATTACHMENT, LOOK BELOW MESSAGE...!
Until another time and greetings to all! ;)
KS!
Last edit: 16 years 10 months ago by alakentu.
16 years 10 months ago #20982 by domenicocg
Encountered two problems in a file at line 840
$ fbConfig-> showvideotag);
Round off the brackets because it created problems in the administrative side.
Other kunena.category.class.php file at line 47 when I was logged in I went home page.
$ cat = $ kunena_db-> loadObject ();
Removing parentheses.
I wanted to ask for confirmation of whether it was correct or not.
hello by Domenico
P.s.: I apologize for my not perfect English.
Time to create page: 0.258 seconds
