- Thank you received: 1
Question Kunena CustomLogin Module
The Kunena login module (1.6rc2) doesn't work at all. I don't get the links, and the login doesn't work. Also, the redirect after clicking the login gives me a 404 error. If I login using Joomla's login menu item, when loging out - again I get the 404 error and stay logged in.
With your integration of Joomla login module and Kunena, everything works fine, except for the links which are missing.
I thought that it might be a language problem (I'm using Hebrew, right to left), but switching to en-GB didn't help.
As for the personal links after logging in, the dorpdown inputs let me choose from any of my defined menus. In my main menu - I have a link to Kunena Forum. This doesn't work. But if I choose the top level of the Kunena_menu (which is installed by Kunena), then it works.
The rest of the menu items (usually to an article, category, contact) work fine.
Thanks for investing time in it and sharing the code. You are really fast and creative!
Emanuel.
- loki34829388
the only reason i can think of that a link won't work is that it isn't published or the user doesnt have permissions to see it - ie 404 error.
i would start with checking to ensure the links in your menu systems are publishd and live. What i would do if you like for organisations sake just create a new menu that isn't in a position on your template. but is published that is specific for links you would like to have in the module. Then you can reference to them in the module and you don't have to edit any preset menu conditions you have made.
So you'll basically have a custom menu that is only for the module. and you can set your on permision levels for the individual link nodes. This will allow for stricter control of what your login is accessing for links.
*** for the front end links not showing up *****
First thing tho is check your generated html source code from a live page with the module and see if they are even loaded at all - yo ucan findthem by searching for the div with .login_frontlinks class.
other things to try are if this is a local setup just removing the Kunena component and clearing the browser and joomla caches to ensure something isn;t hanging up the code then reinstalling.
I know it's hell. I have noticed sometimes something gets buggered in the backend and a reinstall seems to clear things up if there were conflicts with previous installs.
The only reason i can think of that the forgot pass/username and register links dont show would be that CKunena api isnt registering properly so the links aren't coming up. IF the avatar is n0t showing in kunena Avatar mode then it would definately appear that something is going wrong in the kunena api as they are pulled through kunena calls that were used in the kunena login module. In CB mode I use calls from Klogin 1.5.3 that had all three integrations. but kunena didn't work as they appear to have restructured the api for better compliancy thus i changed it out with the updated scripts from Kunena L-module 1.6 rc2.
(wow alot of typing imagine if i was talking)
:side:
Do you have firefox? firephp? firebug?
also other points then to speed this up for you
IRC? MSN?
I'm on msn - PM me for deets
and avail almost always.
- loki34829388
- loki34829388
loki34829388 wrote: Here is updated module for register links.
Params now has option to choose wich frontend link integration to use (which is defaulted to kunena). Joomla's native forms or link to whatever Kunena's integration finds. (my setup appears to be Community builder tho if oyu dont have it i can assume it would use kunena's built in register forms if it has any as it is using the kunena api when it is selected)
thanx guys!
also I hope you guys appreciate the extras i put into it like CSS and personal links!
Any feedback is is appreciated!:dry: - extra features:woohoo: , problems:S , and so forth:whistle: would be good:evil: . Enjoy the mod
I've splited this part of discussion becouse have nothing to do with Kunena Login Module and moved to appropriate category.
Best Regards
