Question Kunena latest posts module - BACKPORTED FOR JOOMLA 1.0
17 years 1 month ago #28695 by Nebiru
Replied by Nebiru on topic Re:mod_kunenalatest
My solution is to compare the $user->gid with the pub_access
to do this replace lines 123 - 134 in .../modules/mod_kunenalatest/helper.php
$i = $show_pub + 2 * $show_reg + 4 * $show_spe; switch ($i) { case 0: $sql_access = 'AND false'; break; case 1: $sql_access = 'AND c.pub_access in (0)'; break; case 2: $sql_access = 'AND c.pub_access in (18)'; break; case 3: $sql_access = 'AND c.pub_access in (0,18)'; break; case 4: $sql_access = 'AND c.pub_access in (19,20,21)'; break; case 5: $sql_access = 'AND c.pub_access in (0,1,19,20,21)'; break; case 6: $sql_access = 'AND c.pub_access in (-1,18,19,20,21)'; break; default: $sql_access = ''; }
with the following code:
switch ($user->gid) { case 0: $sql_access = 'AND c.pub_access in (0)'; break; case 18: $sql_access = 'AND c.pub_access in (0,1,18)'; break; case 21: $sql_access = 'AND c.pub_access in (0,1,18,19,20,21)'; break; case 25: $sql_access = 'AND c.pub_access in (0,1,18,19,20,21,25)'; break; default: $sql_access = 'AND c.pub_access in (0)'; }
And it seems to work.
The topic has been locked.
17 years 1 month ago #28881 by Cosworth
Replied by Cosworth on topic Re:mod_kunenalatest
Nebiru this works fine save for the forums created with groupjive for instance that have pub_access = 30. Now the correct thing to do here would be to initialize $fbsession and access $fbsession->allowed giving you the allowed category id's. Then you could replace the switch statement with:
$sql_access = 'AND c.id in '.$fbsession->allowed
Unfortunately I haven't been able to do that.
17 years 5 days ago - 17 years 3 days ago #31957 by sarkit
Replied by sarkit on topic upgrade Latest post
hi,
i'm using a module..where i can show forums latest post at home..which looks like -
but i want to my latest post like this way -
see..how synchronized the 2nd one is..is there any module or any upgrade version uploaded yet..?
Last edit: 17 years 3 days ago by sarkit.
17 years 3 days ago #32156 by sarkit
Replied by sarkit on topic Re: upgrade Latest post
no reply.. :(
16 years 11 months ago #32790 by ghasem
Fatal error: Class 'fb_config' not found
Kunena1.5.6 :(
16 years 11 months ago #32798 by xillibit
For Kunena 1.5.x series you have kunena discuss plugin which works natively on kunena 1.5.x series : www.kunena.com/forum/113-plugins/23694-k...ss-plugin-j15-native
