Important K 1.5 latest posts module - no longer supported or maintained. Do NOT use this with K 1.6!
16 years 10 months ago #33066 by jerry
Replied by jerry on topic Re:Kunena latest posts module
sytoedov wrote:
I've also found strange issue on one of my configurations.
Using the module wastes extra 10Mb of RAM.
Investigating the culprit I've found that the reason is in loading Community Builder object. Removed the line - got minus 10Mbs of RAM.
I've also found that actually module uses the 5% of the huge Community Builder functionality. I've made special CB class without extra functionality - and this helped me - module was completely function but I've saved 10 Mb.
This was made by the very dirty hack (I am not a developer) so I am just pointing at this trouble - may be this will help someone.
I've done this with CB 1.2.1 and Kunena Latest Module 1.0.45
-- Dam
send me that hack, I will see how dirty it is and i will decide, if it will be included or not.
16 years 10 months ago - 16 years 10 months ago #33086 by Kona Pete
Hi Jerry,
I just installed the your module with Joomla 1.5.9 and Kunena 1.0.8 and when I enable it, I'm not able to access the site from the front end. I get "HTTP 500 Internal Server Error". Any idea what might be causing this?
Thanks, Kona Pete
Last edit: 16 years 10 months ago by Kona Pete.
16 years 10 months ago #33097 by jerry
Kona Pete wrote:
Hi Jerry,
Thanks, Kona Pete
Probably you should upgrade to Joomla 1.5.15 and Kunena 1.5.7, really that's the most tested platform. Your site is vulnerable right now. I am not testing it with that old configuration.
16 years 10 months ago - 16 years 10 months ago #33262 by jpc0480
jerry wrote:
jpc0480 wrote:
This is the error I'm getting:
Fatal error: Cannot redeclare class smile in /home/content/w/o/o/woozabee/html/components/com_kunena/template/default/smile.class.php on line 31
I am using a custom template with Kunena 1.5.6 and installed the latest version of this mod. Not sure if my custom template is causing this or what...
well could be, youst send us template, we will see if we can help or not.
File size is too large... Do you have somewhere else I can send it to you? The file size is 521kb.
Kunena 3.0.4
CB 1.9.1
Joomla 2.5.18
Last edit: 16 years 10 months ago by jpc0480.
16 years 10 months ago - 16 years 10 months ago #33272 by jerry
Try to upload it to some upload service like rapidshare... and put here link.
Last edit: 16 years 10 months ago by jerry.
16 years 10 months ago #33379 by girathryn
Hi there,
Thanks for this module! One little thing I noticed is that when a post title is small enough to fit on one line in the module (next to its avatar), it throws off the alignment of the avatar/latest post beneath it. Any idea how to fix this?
Thanks!
