- Thank you received: 1
Important K 1.5 latest posts module - no longer supported or maintained. Do NOT use this with K 1.6!
There is a conflict between Mosetstree Latest module and Kunena Latest Modules.
It is not possible to display two modules at the same page.
The developer of Mosetstree suggested such a change in class.kunena.php
the thread in mosets forum can be found here:
forum.mosets.com/showthread.php?p=42869&posted=1#post42869
I wouldn't bring this to your attention if it was related with the Kunena Latest module. It is my understanding that a change is needed in Kunena Core in order to eliminate this conflict.
The solution suggested is not a complete solution, because it is still not possible to display "kunena latest" inside a tabbed module, when mosetstree listing module is published as well.
Im using it in conjuction with JomSocial 1.2.202 where i made a custom module position by hacking the frontpage of JS and have loaded your module on that position.
With Kunena 1.0.10 everything works fine, but after an upgrade to 1.5.3 it breaks my jomsocial frontpage like language file is corrupted.
Half of the page have no translation at all.
http://www.jomsocial.com/forum/index.php?id=941&rb_v=file
If i disable module everything works again
Any suggestions where in code i should look?
All worked well on a previous test install.
I recently DUMPED the latest messages from KUNENA via phpmyadmin to this new install Im working on to get all the latest posts. Done this before and all messages are there.
I am noticing now however that not all messages are being shown in the latest posts modole but if I click on the link at the bottom of the latest post module to show all new posts it shows the messages fine.
I tried uninstalling/reinstalling both the edited 1.0.40 and the original 1.0.40 so I dont believe its anything to do with the hacked version.
This all worked FINE before I did the move of all kunena DB to the new kunena DB.
May have something to do with a post I have here as well: ? ago .
- woonydanny
- Elite Member
- Thank you received: 22
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile
Actually Kunena Latest Module is still 3rd party module. If devs fInd some issues, which should be patched in module (not in underlying Kunena component), please contact me.Does this still happen? Hopefully the Kunena devs can have a look at this
We know about issues with JomSocial. These issues are in underlying Kunena component. Fixed in 1.5 svn, so these should be gone when Kunena 1.5.4 would be released.Jerry, thanks for great module, but i have an issue
