Question New users need moderator approval for x first messages
16 years 2 months ago #43475 by igorimc
Hello...
Excuse my english...
Can this hack apply to K1.5.9 ??
Igor!
16 years 2 months ago #43483 by xillibit
yes, you can apply this hack on K1.5.9, the lines number could be different.
16 years 2 months ago #43486 by sozzled
The tip/hack/suggestion posted by Matias in #15410 was written 10 months ago (around the time of K 1.0.9). There have been 8 official releases of Kunena since then.
There are no guarantees that anything written in the this category will work or may continue to work in later releases of Kunena. Further, you would probably be wasting your time modifying K 1.5.9 because K 1.5.10 has already been released (although it's imperfect) and K 1.5.11 will be released very soon. But, even more importantly, just as K 1.5 made considerable changes to the way that K 1.0 was built, the next generation K 1.6 will invalidate many of the coding structures and conventions used in K 1.5.
Although the ideas used in this topic are still relevant to those perhaps looking for a solution, the implementation of them is outdated.
16 years 2 months ago #43495 by igorimc
I have disturbed Matias... very very gentleman...
The solution for 1.5.9:
in /components/com_kunena/template/default/post.php
around line number 443 I have this code:
$holdPost = $kunena_db->loadResult(); } // // Final chance to check whether or not to proceed
ok...
replace with:
$holdPost = $kunena_db->loadResult(); } $kuser = new CKunenaUserprofile(); if ($kuser->posts < 1) $holdPost = 1; // // Final chance to check whether or not to proceed
This solution work fine in 1.5.9.
...$kuser->posts < 1... set the numeber of messages.
This solution is not perfect for robot post, I have set $kuser->karma < 1
In this mode I assign karma to user that can post directly.
Thanks for support Matias.
Bye
Riboni Igor
16 years 2 months ago #43521 by Matias
It was a nice trick to change review for people with low karma. Just do not tell it to your users, or they will use it in the wrong way. :)
BTW: if you want to make the karma version better, you should disallow normal users (not moderators) to lower karma to less than 1 and from 0 to 1. That would make it perfect.
16 years 1 month ago #44571 by kd0bik
I'm running Kunena 1.5.11 on Joomla 1.5.15. Does anyone know if this modification works for having x many messages requireing moderator approval?
Also, does anyone know if Kunena is planning to incorporate this feature in a future release? This functionality is available in many message boards. I love Kunena for my Joomla site. But I feel it lacks in the area of moderation.
JT
Time to create page: 0.273 seconds
