Question How to Convert from IPB 3.1.2 to Kunena 1.6.3
14 years 11 months ago - 14 years 11 months ago #98916 by dewojcik
Again thank you - here is that report
htaccess: Exists | PHP environment: Max execution time: 45 seconds | Max execution memory: 96M | Max file upload: 24M
Joomla default template details : rt_zephyr_j15 | author: RocketTheme, LLC | version: 1.5.2 | creationdate: November 16, 2010
Kunena default template details : Integrity Pro Kunena 1.6 Template | author: TemplateKunena Team | version: 1.6.2 | creationdate: 2011-01-24
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 2.0.4) | UddeIm: Disabled or not installed
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Disabled | JFirePHP: Disabled or not installed | Kunena Discuss: Disabled or not installed | Kunena Search: Enabled (Version : 1.6.2) | My Kunena Forum Menu: Enabled (Version : 1.6.2) | My Kunena Forum Posts: Enabled (Version : 1.6.0-RC1)
Last edit: 14 years 11 months ago by dewojcik.
14 years 11 months ago - 14 years 11 months ago #98918 by sozzled
K 1.6.3 is not supported and the Kunena add-ons that you are using are, likewise, unsupported. K 1.6.4 fixed about 150+ issues and we recommend that you upgrade to that version as soon as possible. K 1.6 4 made all previous releases of Kunena obsolete.
Please read the information in the FAQ about editing your configuration report. Editing your configuration report is unnecessary unless you do not want the moderators here to be made aware of certain information. Information that you think may be unimportant (or irrelevant) to your circumstances is still information that may possibly assist us to help you to solve your problems.
Good luck. I think the upgrades will solve your problems. :)
Last edit: 14 years 11 months ago by sozzled.
14 years 11 months ago #98920 by dewojcik
Thanks again - I will upgrade right away and report back the result
14 years 11 months ago - 14 years 11 months ago #98921 by dewojcik
The upgrade was successful - here is the new configuration report (unedited)
Third-party components: Jomsocial 2.0.4
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Search 1.6.2 | My Kunena Forum Menu 1.6.2 | My Kunena Forum Posts 1.6.0-RC1
Modules: Kunena Latest 1.6.2 | Kunena Search 1.6.2
14 years 11 months ago #98922 by dewojcik
Unfortunately I still get the same issue with the Topic links all going to the same starting topic page.
14 years 11 months ago #98923 by dewojcik
Ahh silly me - I still need to update the plugins by hand
Time to create page: 0.271 seconds
