This is not a support forum for AlphaUserPoints or its related products. For AlphaUserPoints support you should visit AlphaPlug .
The information given in this category is intended to guide users who want to use AlphaUserPoints with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of AlphaUserPoints.
Important Kunena AUP plugin not working with Jomsocial
12 years 4 months ago #157741 by woonydanny
ok cheers.
i must be thinking of another problem then. i cannot get kunena activities to show in my jomsocial stream when i have aup enabled.
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile :(
12 years 3 months ago #157756 by xillibit
I'am afraid that the issue is come back, can-you put here please your Kunena configuration report ?
12 years 2 months ago #158970 by artweb
We have the same problem. We run Joomla 2.5.20, Jomsocial 3.2.1.3, AUP 1.8.9 and we have just upgraded to Kunena 3.0.6 from 3.0.5. Before all worked well, but right after the upgrade, the posts from Kunena no longer appear on Jomsocial wall. It looks like the bug has been re-introduced with the latest Kunena version. Please help. I can pay for it.
12 years 2 months ago #158979 by xillibit
You can apply this fix untill that we release a maintenance release : github.com/Kunena/Kunena-Forum/commit/81...d26a2dacd82e2417a6c6
12 years 2 months ago #158995 by artweb
many thanks, this has solved the issue!
11 years 10 months ago #161174 by xristo
artweb wrote: many thanks, this has solved the issue!
Which issue is solved? The AlphaUserPoints integration (per the post topic) or this misc. add-on with TapTalk?
