This is not a support forum for AlphaUserPoints or its related products. For AlphaUserPoints support you should visit AlphaPlug .
The information given in this category is intended to guide users who want to use AlphaUserPoints with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of AlphaUserPoints.
Important Kunena AUP plugin not working with Jomsocial
13 years 1 month ago #149524 by woonydanny
htaccess: Exists | PHP environment: Max execution time: 9900 seconds | Max execution memory: 1024M | Max file upload: 1024M
Joomla default template details : shape5_vertex | author: Shape5.com | version: 2.0 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.2 | creationdate: 2013-08-18
Third-party components: AlphaUserPoints 1.8.3 | Jomsocial 3.0.4
Plugins: Search - Kunena Search 3.0.1 | Content - Kunena Discuss 3.0.1
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Login 3.0.1 | Kunena Search 3.0.1
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile :(
13 years 3 weeks ago #149897 by woonydanny
matias, any idea regarding this issue with kunena plugins?
13 years 2 weeks ago #149988 by Matias
It's likely in our code.
Added a bug on it:
github.com/Kunena/Kunena-Forum/issues/2076
The following user(s) said Thank You: woonydanny, xristo, Shaun Downend
13 years 2 weeks ago #150021 by woonydanny
it does sound like multiple kunena integration plugins dont work well with each other when they are both published.
hopefully you can narrow down the cause. many thanks :)
13 years 2 weeks ago #150027 by Matias
Might be related on how they are called because of it used to be true. There could be only one integration enabled at a time in K1.7...
I thought I fixed that, but maybe there's still some old calls or a bug in the function...
The following user(s) said Thank You: woonydanny, Shaun Downend
13 years 1 week ago #150277 by woonydanny
ok, thanks for letting me know. I assume there must still be a small bug that means it does not work properly.
would be good when that is fixed so Kunena, Jomsocial and AUP can run harmoniously together!!!
thanks
