Question Search Module Not Showing
15 years 9 months ago #83537 by somonline
I am very new to the Kunena world. So this issue might be very trivial to the devs.
I am not able to see ant search module in my Kunena forum.
Generally, as I see it in this forum, the search module should be there beside the login module. Isn't it ?
Can someone guide me with steps to follow to get the search module up please ? :(
Do I have to install the module separately or it comes within the default installation ?
Thanks in Advance..
15 years 9 months ago #83555 by xillibit
You need to download this module here : joomlacode.org/gf/project/kunena/frs/
and then set it in position kunena_profilebox
15 years 9 months ago #83562 by somonline
Thanks for the quick reply.
I installed the search module from mod_kunenasearch_v1.6.2_b47_2010-12-29.zip
and set the position to kunena_profilebox. But still search is not showing. Only login details are showing in the box. :dry:
15 years 9 months ago #83573 by fxstein
Please post you config report and a screenshot of the search module settings.
Thx!
15 years 9 months ago #83687 by somonline
fxstein wrote: Please post you config report and a screenshot of the search module settings.
Thx!
Here is the screenshot >
I got this after "Report Configuration Settings" >
Kunena Control Panel Forum Configuration Category Manager User Manager Template Manager Emoticon Manager Rank Manager Uploaded Files Browser Uploaded Images Browser Prune Forums Synchronize Users Recount Category Statistics Trash Manager General Statistics Report Configuration Settings Support Web Site
Fatal error: Call to undefined method JFactory::getTemplate() in C:\Program Files\XAMPP\xampp\htdocs\myjoomla\administrator\components\com_kunena\admin.kunena.php on line 3053
15 years 8 months ago - 15 years 8 months ago #90367 by kozzmic
I have the same problem. Its also on the kunena_profilebox position but doesnt show. When i do custom html it shows that, but ,not this module.
htaccess: Exists | PHP environment: Max execution time: 1000 seconds | Max execution memory: 64M | Max file upload: 10M
Joomla default template details : yoo_pure | author: YOOtheme | version: 5.5.2 | creationdate: February 2011
Kunena default template details : Reddy | author: gonzaunit | version: 1.6.0 | creationdate: 2010-07-04
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Disabled or not installed | UddeIm: The file doesn't exist uddeim.j15.xml !
Last edit: 15 years 8 months ago by kozzmic.
