Question
Kunena Latest plugin for 1.6.2 does not work unless logged in
I have the same problem BUT the restriction seems to go away if you select "ALL/NONE" in the filters window. This is not a fix it is a work around.., I also am looking for a fix to this AS the code should have an option to Display to guests with the links going to the registartion page or a message that states that you must register. I think we need to find the people who own this module and ask them for help.
There is also another problem with the module as it needs an option to add am menuID so a template can be assigned to the link
Richardkl wrote: I have the same problem BUT the restriction seems to go away if you select "ALL/NONE" in the filters window. This is not a fix it is a work around..
When I edit the parameters in the module for Categories to Display to All/None, it still only shows topics in public sections/categories unless a user is logged in.:dry:
It says it's an official module by the Kunena team so hopefully we can get some help.
