Question [Resolved] Kunena Latest Posts (caching issues)
14 years 10 months ago #113507 by detailer
sorry i didn't get you in previous reply, report is added please have a look. :)
14 years 10 months ago #113509 by sozzled
You are using the wrong version of Kunena Latest module and the Kunena Stats module and if you look at the article Improving Kunena performance you will see that your version of JomSocial is probably the reason for some of the performance problems that you are having.
If you had posted your configuration report in the first place you would not have had to wait for a day for a reply.
You also seem to have an issue (possibly a menu conflict) with the way you've setup your Kunena menu. I can't see any other particular reasons why you should be having problems. You should certainly not be experiencing load difficulties with only 20 users and a handful of forum topics.
One subject per topic. This helps you; it helps us and it helps other people looking for the answers. Your other "problem" deserves a separate discussion. Please explain (when you create your other topic) what is the specific issue that you want to solve and why the issue is important for you and the users of your forum. Thank you.
14 years 10 months ago #113518 by detailer
thanks for reply, yes i will be careful for that.
Yes i updated both modules to the latest version, seems module is working fine with cache enabled and overall site performance is also good.
Did not do anything with kunena menu, this is what came up by default with installation.
But video problem is still exists.... any idea?
14 years 10 months ago #113523 by sozzled
detailer wrote: But video problem is still exists.... any idea?
What is the specific problem? How big do you want to make the YouTube player? Separate topic please.
