Idea Enabling Discuss bot in 3rd party components
16 years 4 weeks ago #67858 by gray
I successfully enabled the bot in a component (not com_content).
Still I run into a problem.
When the post is published, page is being reloaded. It's done by the code on lines 437-440
// Redirect $uri = JFactory::getURI (); $app = JFactory::getApplication ( 'site' ); $app->redirect ( $uri->toString (), $result );
My problem is that $uri->toString () returns BOTH the SEF and not-SEF link as one string.
To fix the problem I used JURI::current().
It seems to work in articles also.
But my questions is why 2 links are returned in one string by $uri->toString ()?
www.justPHP.net - Custom coding for Joomla!
16 years 4 weeks ago - 16 years 4 weeks ago #68103 by gray
Partially clarified the issue. It happens only with SEF enabled. For some components $uri->toString () return path + query. I think it's due to improper routing
JURI Object ( [_uri] => http://111.blabla.com/blabla/blabla/591_blabla [_scheme] => http [_host] => 111.blabla.com [_port] => [_user] => [_pass] => [_path] => /blabla/blabla/591_blabla [_query] => option=com_combla&view=blaview&layout=bla&id[0]=591 [_fragment] => [_vars] => Array ( [option] => com_combla [view] => blabiew[layout] => blalayout [id] => Array ( [0] => 591 ) ) [_errors] => Array ( ) )
When viewing an article, the [_query] is empty and only the path is returned, that is OK.
My workaround was to replace in
$uri->toString () with $uri->_uri
Last edit: 16 years 4 weeks ago by gray.
15 years 10 months ago #79158 by kayrozen
Hi ! I would like to enable discuss bot 1.6.2 in EventList 1.1. Eventlist has already a comments implementation (Jcomments...ect)
Does your solution would work with my needs ?
15 years 10 months ago #79163 by kayrozen
Hi ! I'm not much a coder but I am willing to test it and give you help.
I'm using K1.5 with a discussbot hacked plugin to display comments in eventlist 1.0.1 ( www.kunena.org/forum/113-user-written-pl...t-and-kunena-discuss ).
I'm looking forward to upgrade to K1.6.2 with the new discussion plugin and EventList 1.1.3 ( www.jlv-solutions.com/support/6-community-support-11x ) and searching some help to guide me integrate both. I know that Eventlist can use an external comment system (Jcomments, JOMcomments...) and im searching if it can work and how to do it (even if i need to maintain that hack, like i do with my actual solution)
Just drop me a line :)
15 years 8 months ago #88002 by stigzelm
does this work for eventlist??
15 years 8 months ago #88709 by stigzelm
How did you manage to get discuss bot integrated with another component? I would also like to have it integrated with eventlist.. Please tell me what you modified and how.
