Idea [Gelöst] SQL: Kompatibilität
Do you have access to phpMyAdmin or similiar? Try to run these queries in there:
If this doesn't work, your installation has failed:
SELECT * FROM joomla_fb_messages LIMIT 1
These are to locate the problem:
SELECT a.thread, a.subject FROM joomla_fb_messages AS a WHERE a.parent=0 AND a.moved=0 AND a.hold=0 GROUP BY a.thread LIMIT 100
SELECT thread, MAX(time) AS lastpost FROM joomla_fb_messages WHERE time >'1231500912' AND hold=0 AND moved=0 AND catid IN (1,2,3,5,4,6,7,8,9,10) GROUP BY 1
SELECT a.thread, a.subject, b.lastpost FROM joomla_fb_messages AS a JOIN ( SELECT thread, MAX(time) AS lastpost FROM joomla_fb_messages WHERE time >'1231500912' AND hold=0 AND moved=0 AND catid IN (1,2,3,5,4,6,7,8,9,10) GROUP BY 1) AS b ON b.thread = a.thread WHERE a.parent=0 AND a.moved=0 AND a.hold=0 GROUP BY a.thread ORDER BY b.lastpost DESC LIMIT 100
Any results?
Here is the Sql Error:
Error
SQL query: Documentation
JOIN (
SELECT thread, MAX( time ) AS lastpost
WHERE time > '1231500912'
AND hold =0
AND moved =0
AND catid
IN ( 1, 2, 3, 5, 4, 6, 7, 8, 9, 10 )
GROUP BY 1
WHERE a.parent =0
AND a.moved =0
AND a.hold =0
GROUP BY a.thread
LIMIT 100
MySQL said: Documentation
#1064 - You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near 'SELECT thread, MAX(time) AS lastpost FROM joomla_fb_messages WH
Yes, she did. She wanted it also for a regular bug reporting in German.@ Lintzy: did you post this one in English?
so... did the SQL-timeout produced this error??
@ Lintzy: did you post this one in English? It is installation timeout problem. You need to add php timeout to 60-90 secs during installation.
Yes, I did, it it the same case. And same question here: How to add php timeout to 60-90 (or 120) secs?
