- Thank you received: 4
Idea [Gelöst] SQL: Kompatibilität
Auf dem ersten Screenshot ist deine Datenbank zu sehen, auf dem zweiten eine von mir, die Kollation ist blau umrandet.
EDIT: Lies mal in diesem thread . Derselbe Fehler - behoben durch Wechseln des Templates von default_ex nach default. :silly:
@ dazzafact: I'd like to see your joomla_fb tables in your MySQL server.. I'm as confused as you are.. Can you PM me?
Looks like we are hitting an old MySQL bug. This seems to be very specific to a certain MySQL version.
We are investigating options on how to circumvent this problem.
We will keep you posted!
Have a great day!
fxstein
SELECT a.id FROM `jos_users` AS a JOIN (SELECT id, name AS foo FROM `jos_users`) AS b ON a.id = b.id
So derived tables are not working. The odd thing is that I have the same MySQL version and the same queries work in my own computer.
Server Version: 4.0.25-Max-log
MySQL-Client-Version: 5.0.67
Client API version 5.0.67
littlebit confused :S :side:
Provider Support:
Hello...
in PHPMyAdmin also is written that the "5" is attributable for the MySQL-Client-Version (Version of PHPMyAdmin)
Provider Support:
Hallo...
im PHPMyAdmin steht aber auch, dass es sich bei der 5 um die MySQL-Client-Version (Version des PHPMyAdmin) handelt.
You have too old MySQL server. Derived tables came in 4.1 and minimum version for FB/Kunena is 5.0.
So you really need to update MySQL server -- Kunena uses many MySQL 4.1/5.0 features.
