Kunena 7.0.8 Released
Loved Kunena 1.0.10 und 1.0.11 Template - Lintzys Summerdream - deutsch
add this at the start of your file (/homepages/5/d273576007/htdocs/j/components/com_kunena/template/ lintzys_summerdream/view.php) :
@ Lemur:
Installiere Kunena 1.0.10
Installiere das Zeitfile
und installiere dann Lintzys Summerdream.
KEIN Recoverpack
Versuche mal folgendes: Installiere einfach Zeitfile und anschließend das Template noch einmal.
Hier steht auch eine Installationsanleitung, genau wie in dem Readme.txt übrigens.
templates.webdesign-welt.de/kunena-templ...uer-kunena-1010.html
thanks xillibit, but this is implemented by default in my template.
@ Lemur:
KEIN Recoverpack
Thank you,
after installing Kunena 1.0.10 I have installed
Sprach-und Zeitdateien komplett (Komplettes Sprachpaket für Kunena 1.0.10 (formal) plus Änderung des Zeitformats).
So, i have euro-time format and dates are schown well in posts.
If I search for a word with a search field , I get a relevante list of articles. Dates are OK!
And only if I at the moment go to one of article's title from that list, I get an anomalous page with the error "Fatal error: Call to undefined function changedate() in /homepages/5/d273576007/htdocs/j/components/com_kunena/template/lintzys_summerdream/view.php on line 984". (As on image)
Muss Ich trotzdem versuchen: "Installiere einfach Zeitfile und anschließend das Template noch einmal."?
Danke.
Signature:
Many thanks to Rich and the other advisors.
the error is not produced by lintzys_summerdream template.
The problem is situated, that euro-date in german translation and the solution for "Warnings in search" does not fit together.
I will describe it in that topic
www.kunena.com/forum?func=view&catid=93&...08&limit=10&start=20 ]
wenn it will not be locked.
Signature:
