Kunena 7.0.8 Released
Loved Yes, it really IS possible to install K 1.6.4 on Joomla 1.5!
15 years 3 months ago #94724 by blindek
These error I get when I copy the download link in the "Install Manager" . These error is the first screen witch I get. In the "Componets" tab the "Kunena forum" menu appear but when I click it i get the same error:
Fatal error: Uncaught exception 'KunenaInstallerException' with message 'Unknown column 'id' in 'order clause' SQL=SELECT * FROM `jos_fb_version` ORDER BY `id` DESC LIMIT 0, 1' in /var/www/vhosts/callofduty.si/httpdocs/administrator/components/com_kunena/install/model.php:1132 Stack trace: #0 /var/www/vhosts/callofduty.si/httpdocs/administrator/components/com_kunena/install/model.php(1057): KunenaModelInstall->getInstalledVersion('fb_', Array) #1 /var/www/vhosts/callofduty.si/httpdocs/libraries/joomla/application/component/view.php(364): KunenaModelInstall->getDetectVersions() #2 /var/www/vhosts/callofduty.si/httpdocs/administrator/components/com_kunena/install/view.php(50): JView->get('DetectVersions') #3 /var/www/vhosts/callofduty.si/httpdocs/administrator/components/com_kunena/install/controller.php(53): KunenaViewInstall->display() #4 /var/www/vhosts/callofduty.si/httpdocs/libraries/joomla/application/component/controller.php(236): KunenaControllerInstall->display() #5 /var/www/vhosts/callofduty.si/httpdocs/administra in /var/www/vhosts/callofduty.si/httpdocs/administrator/components/com_kunena/install/model.php on line 1132
15 years 3 months ago #94744 by xillibit
Check that in your table jos_fb_version you have right a column nammed id.
15 years 3 months ago - 15 years 3 months ago #94820 by blindek
My jos_fb_version looks like that. What I have to do here?
localhost:3306 - codsi2_joomla2 - jos_fb_version
Field Type Collation Attributes Null Default Extra version varchar(10) utf8_general_ci No date int(8) No 0
Last edit: 15 years 3 months ago by blindek.
15 years 2 months ago #95111 by blindek
15 years 2 months ago #95115 by xillibit
I need to check it by myself
15 years 2 months ago #95122 by xillibit
Can-you just export the table jos_fb_version and give me the result ?
Time to create page: 0.247 seconds
