Loved Yes, it really IS possible to install K 1.6.4 on Joomla 1.5!
15 years 4 days ago - 14 years 11 months ago #94417
It has always been possible to install K 1.6 on J! 1.5. Please read
K 1.5 Technical Requirements
and
K 1.6 Upgrade Guide
Last edit: 14 years 11 months ago by sozzled.
15 years 3 days ago #94489
by blindek
Replied by blindek on topic Is it possible to install K 1.6.4 on Joomla 1.5?
Thank you for your help. I followed the instructions but I get the following error, I also searched over internet, but no one has the same problem. Can you help me with these?
I also uninstall previus kunena and fireboard versions and uninstall all modules.
Fatal error: Uncaught exception 'KunenaInstallerException' with message 'Unknown column 'id' in 'order clause' SQL=SELECT * FROM `jos_fb_version` ORDER BY `id` DESC LIMIT 0, 1' in /var/www/vhosts/callofduty.si/httpdocs/administrator/components/com_kunena/install/model.php:1132 Stack trace: #0 /var/www/vhosts/callofduty.si/httpdocs/administrator/components/com_kunena/install/model.php(1057): KunenaModelInstall->getInstalledVersion('fb_', Array) #1 /var/www/vhosts/callofduty.si/httpdocs/libraries/joomla/application/component/view.php(364): KunenaModelInstall->getDetectVersions() #2 /var/www/vhosts/callofduty.si/httpdocs/administrator/components/com_kunena/install/view.php(50): JView->get('DetectVersions') #3 /var/www/vhosts/callofduty.si/httpdocs/administrator/components/com_kunena/install/controller.php(53): KunenaViewInstall->display() #4 /var/www/vhosts/callofduty.si/httpdocs/libraries/joomla/application/component/controller.php(236): KunenaControllerInstall->display() #5 /var/www/vhosts/callofduty.si/httpdocs/administra in /var/www/vhosts/callofduty.si/httpdocs/administrator/components/com_kunena/install/model.php on line 1132
15 years 3 days ago #94503
Replied by sozzled on topic Is it possible to install K 1.6.4 on Joomla 1.5?
Is this your website
callofduty.si/forum
... you are trying to upgrade from Fireboard, yes?
Which version of Fireboard are you using? Which version of Joomla are you using?
15 years 3 days ago - 15 years 3 days ago #94506
by blindek
Now I restore the backup because of that is Fireboard again. When I got these error I removed fireboard and I tried to upgrade the Kunena 1.5 . Also I tried to remove Kunena 1.5 and install fresh Kunena 1.6, but I get the same error.
Any advice?
I am also prepared to loose al my threads, so maybe an database flush or smth?
I am using:
Joomla! 1.5.15 Stable [ Wojmamni Ama Mamni ] 05-November-2009 04:00 GMT
Any advice?
I am using:
Last edit: 15 years 3 days ago by blindek.
15 years 3 days ago #94510
Replied by sozzled on topic Re: Is it possible to install K 1.6.4 on Joomla 1.5?
If you read the
technical requirements
(I mentioned it in the first post in this topic) you will see that you cannot install K 1.6.4 on J! 1.5.15. Please upgrade to J! 1.5.23 first.
What version of Fireboard are you trying to upgrade from? FB 1.0.0, FB 1.0.1, FB 1.0.2, FB 1.0.3, FB 1.0.4, FB 1.0.5 rc 2? Which version, please?
15 years 1 day ago #94723
by blindek
Replied by blindek on topic Re: Is it possible to install K 1.6.4 on Joomla 1.5?
Now I have updated my Joomla (Joomla! Version: Joomla! 1.5.23 Stable [ senu takaa ama baji ] 04-March-2011 18:00 GMT ) but I have the same problem as before.
I have these fireboard (fireboard Enabled 1.0.5NB2 2008-07-08 Best Of Joomla!)
Time to create page: 0.210 seconds
