Question Error on Installation
In total i have 2 menus a top menu and a kunena menu. The top menu has 2 links to kunena and the kunena menu is all kunena links. the kunena menu was created w/ the Kunena menu creator. The top menu i put together myself.
I dont understand how this effects SEO.
If you read the topic [Merged topic] How do I restore my Kunena menu? - and other topics (Would you like me to give you a list of them?) - you will see that Joomla SEO is related. Because you have asked, I will try to explain. When you use Joomla SEO, Joomla uses the menu alias as the basis for generating SEF URLs. If you have two menus with the same menu alias then the Joomla routing process will be unable to resolve the true address and your the site will, effectively, crash with "redirection errors" - the actual errors differ depending on which browser you use. Now, I could spend a lot of time explaining why, how and where Joomla SEO is involved, if you are really interested and you have the time. But would you like a detailed explanation that will help you "understand how this affects SEO" or would you rather fix the problems that you are having?
If you want to create your own custom menus, I suggest you read Customised menus in the Wiki.
*** End off-topic ***
Have you fixed the problem that was preventing you re-installing 1.6.3?
I also emptied the menu trash. Each menu has it's own unique name to it. Which i have had since the start of my site.
I am by no means a expert with Joomla. That's why i have asked for help i have read the actical about restoring the Kunena Menu.
We fixed the Joomla SEO issue (the problem was that the user was not using a renamed htaccess.txt file in place of the .htaccess file). We also fixed various problems with the Joomla/Kunena menus. The user has also managed to repair (replace is a better word) a corrupted database and we are now waiting to see if this fixes the inability to re-install K 1.6.3. Fingers crossed.
I did have to create a new joomla DB and it was a lot more work then i thought it would be. it involde editing a lot of php files but all is working good now.
I also had no problem reinstalling 1.6.3 after the DB problem was solved.
