Question Error on Installation
15 years 8 months ago #90450 by thetoast
I was sent a copy of K1.6.4dev because of the cashiable error. when replying to a post. (Thank god i backed up). I am getting an error and can NOT get past the first steps of installation. This is the error i get when installing:
Prepare Installation ... OK
... FAILED Uncaught Exception: Can't find file: './teamecla_jo151/jos_kunenadiscuss.frm' (errno: 13) SQL=SHOW COLUMNS FROM `jos_kunenadiscuss`
I also get this error when trying to install 1.6.3 again to revert. I did at one point have Kunena Discuss Bot installed but removed it cause it got abused.
15 years 8 months ago #90457 by xillibit
Replied by xillibit on topic Re: Error on Installation
Can-you put here please your kunena configuration setting ?
15 years 8 months ago #90480 by thetoast
Replied by thetoast on topic Re: Error on Installation
sorry about that.
htaccess: Exists | PHP environment: Max execution time: 45 seconds | Max execution memory: 96M | Max file upload: 24M
Joomla default template details : game_crusade | author: Shape5.com | version: 1.0 | creationdate: December 2009
Kunena default template details : InfinityHU | author: PedroHSI | version: 1.6.0 | creationdate: 2010-07-21
Third-party components: AlphaUserPoints: Installed (Version : 1.5.13) | CommunityBuilder: Disabled or not installed | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.3)
Modules: Kunena Latest: Disabled or not installed | Kunena Stats: Enabled (Version : 1.6.2) | Kunena Login: Enabled (Version : 1.6.2)
15 years 8 months ago - 15 years 8 months ago #90503 by sozzled
Replied by sozzled on topic Re: Error on Installation
thetoast wrote: I am getting an error and can NOT get past the first steps of installation. This is the error i get when installing:
The error message indicates there is a table in your database named jos_kunenadiscuss. Although you may have uninstalled a previous installation of the Kunena Discuss plugin (or maybe the old K 1.5 discussbot plugin) there is something left behind in your database from that old installation. Maybe you can rename the table jos_kunenadiscuss to something else (like jos_old_kunenadiscuss) and try the upgrade again?
I also recommend that you upgrade to J! 1.5.22 as soon as possible and that you read about how to implement Joomla Search Engine Optimisation (SEO)
15 years 8 months ago - 15 years 8 months ago #90507 by thetoast
What would happen if i just dropped that table from the data base? Would that work?
Yeah i know my joomla is not up to date, but i have been holding off since 1.6 came out, cause i just want to upgrade to that version as soon as i know most plugins and modules i use will work.
Every time i enable SEO my whole site gets all screwy. So i gave up on that but would be willing to pay someone to do it for me.
Last edit: 15 years 8 months ago by thetoast.
15 years 8 months ago - 15 years 8 months ago #90512 by sozzled
Your site goes "screwy" when you implement SEO because you have lots and lots and lots of Joomla menu items pointing to Kunena and most of the links conflict with one another. We've had many discussions about trashing all existing Kunena menus and menu items, permanently emptying the Joomla menu trash, and using the Kunena Create Menu feature on the Kunena control panel. Have you seen these discussions? See [Merged topic] How do I restore my Kunena menu? If you still cannot get your menu fixed (and therefore you are able to enable SEO) then send me a PM and I might have a look at things for you.
Yes, you can drop the jos_kunenadiscuss table, if you are 1000% certain that it will not totally screw up the rest of your site.
