Question Kunena 1.6.3 and joomla 1.6 working
15 years 8 months ago #88443 by tlavalle
ok i got joomla 1.0.15 and fireboard 1.0.3 install i ran the convert file and get this error SELECT id FROM '**********************`.`jos15_core_acl_aro_groups` WHERE name='Registered' OR name='Administrator' ORDER BY name ASC
Unknown column 'id' in 'field list' now the joomla 1.0.1s is a clean site
15 years 8 months ago #88444 by sozzled
Did you first edit the converter as instructed to do so in the Wiki article?
15 years 8 months ago - 15 years 8 months ago #88479 by tlavalle
yep, i change database, user, password and such.
3-9-2011
ok got around that now i tried to get the fb converter but that says permission denied is there anyother place i can get it?
Last edit: 15 years 8 months ago by tlavalle. Reason: update on conversion
15 years 8 months ago #88526 by sozzled
tlavalle wrote: i tried to get the fb converter but that says permission denied is there anyother place i can get it?
Can you post a screenshot of the page on which you see this message, please?
15 years 8 months ago #88676 by tlavalle
ok i have a clean install of fireboard and kunena on a joomla 1.5.22 but when i do the migrate from fb to kunena i get this error:
Fatal error: Cannot redeclare class KunenaFactory in ************/html/joomla1_5/administrator/components/com_kunena/install/upgrade/upgrade-1.6.0_configuration.php on line 71
what do i need to do?
15 years 8 months ago #88677 by sozzled
If you have Fireboard installed with your phpBB3 converted forum intact on your J! 1.5.22 site (obviously you need to be running in "legacy mode" to allow this to happen) you probably do not need to have Kunena installed in order to do the migration to K 1.6.
The K 1.6 upgrade actually does the migration for you.
Therefore, this is my suggestion: uninistall the Kunena installation; then follow the upgrade guide in the Wiki to go straight from Fireboard to K 1.6, then uninstall Fireboard, disable "legacy mode" and you should have your phpBB3 forum running in K 1.6 (on a J! 1.5.22 platform).
Going from J! 1.5 to J! 1.6 is going to be a tough assignment. I haven't encountered anyone who has made the jump successfully yet. Good luck.
The following user(s) said Thank You: tlavalle
