Question [SOLVED] upgrade error: unable to write entry
15 years 9 months ago #83571 by madLyfe
k cuz i tried to use the "reinstall" feature in the kunena installer and i still got the error..
word up!
15 years 9 months ago #83572 by fxstein
no - don't use the reinstall it will give you the very same error
also don't use the remove feature in the Kunena installer, as it will remove all the database data.
Use the Joomla installer, uninstall Kunena and install it again. (might want to check in the file system if the uninstall truly removed the com_kunena folder in components and administration.
Any one file that got changed manually (permissions) can cause that.
15 years 9 months ago #83575 by madLyfe
both the com_kunena folders were removed with the uninstall. and i didnt get any errors this time on the reinstall. thanks for your help fxstein.
word up!
Time to create page: 0.178 seconds
