Question [SOLVED] upgrade error: unable to write entry
15 years 9 months ago - 15 years 9 months ago #83523 by madLyfe
i got this upgrade error when trying to upgrade from 1.6.2 to 1.6.3, but it looks like everything down below went fine..
word up!
Last edit: 15 years 9 months ago by fxstein.
15 years 9 months ago #83556 by xillibit
this joomla error doesn't help very much :(
15 years 9 months ago #83558 by madLyfe
heh ya im not sure what to make of it either..
word up!
15 years 9 months ago #83561 by fxstein
This is the Joomla installers cryptic way of telling you there was a permissions problem. You might have changes 1 or a few files by hand and the Joomla installer cannot remove/overwrite the file(s).
You can try to uninstall Kunena in the Joomla extensions manager and then do a fresh install. (As always: backup highly recommended!)
15 years 9 months ago #83566 by madLyfe
if i uninstall it and install it again, i will lose my kunena setup right?
word up!
15 years 9 months ago #83570 by fxstein
no - everything will stay as it is kept in the database. Still backup - just to be safe.
