Question [solved] how to install Kunena 1.6.1?
15 years 6 months ago - 15 years 6 months ago #69254 by insanojaco
I already have Kunena 1.6 installed, I need to uninstall 1.6 to install 1.6.1?
Because I tried to install 1.6.1 over 1.6 and it gets the error: Unable to find install package.
Last edit: 15 years 6 months ago by fxstein.
The topic has been locked.
15 years 6 months ago #69256 by sozzled
Can you please show us two pictures:
(1) the image of the screen BEFORE you get the "Unable to find install package" message; and
(2) the image of the screen that shows us the "Unable to find install package" message.
Thank you.
15 years 6 months ago #69258 by fxstein
This is most likely a limit on your server. Kunena 1.6.1 with all the languages is now over 2MB in size. Some servers have a 2MB limit in place.
The work around is very simple. Just do the install by URL and use the link from our download server like that:
Hope this helps!
The following user(s) said Thank You: Smoothound, insanojaco, patricia, leanne
15 years 6 months ago #69275 by insanojaco
fxstein wrote: This is most likely a limit on your server. Kunena 1.6.1 with all the languages is now over 2MB in size. Some servers have a 2MB limit in place.
Hope this helps!
it works! thanks a lot :)
15 years 6 months ago #69605 by Smoothound
Replied by Smoothound on topic Error Uploading
Hi
I have several sites all running Joomla 1.5.20+ and all of them have Community Builder v1.2.3
I can install/upgrade K1.6.0 without any problem, but when I try to upgrade to K1.6.1 it fails and all I get is the following error message in Joomla.
There was an error uploading this file to the server
Any ideas would be appreciated.
15 years 6 months ago #69613 by Smoothound
Should have looked here first.
www.kunena.org/forum/173-k-16-installati...o-install-kunena-161
The same solution works for me.
Time to create page: 0.296 seconds
