Kunena 6.2.6 released
Question [solved] how to install Kunena 1.6.1?
- insanojaco
- Topic Author
13 years 5 months ago - 13 years 5 months ago #1
by insanojaco
[solved] how to install Kunena 1.6.1? was created by insanojaco
I already have Kunena 1.6 installed, I need to uninstall 1.6 to install 1.6.1?
Because I tried to install 1.6.1 over 1.6 and it gets the error: Unable to find install package.
Last edit: 13 years 5 months ago by fxstein.
The topic has been locked.
13 years 5 months ago #2
Replied by sozzled on topic [solved] how to install Kunena 1.6.1?
Can you please show us two pictures:
(1) the image of the screen BEFORE you get the "Unable to find install package" message; and
(2) the image of the screen that shows us the "Unable to find install package" message.
Thank you.
Thank you.
13 years 5 months ago #3
by fxstein
Replied by fxstein on topic [solved] how to install Kunena 1.6.1?
This is most likely a limit on your server. Kunena 1.6.1 with all the languages is now over 2MB in size. Some servers have a 2MB limit in place.
The work around is very simple. Just do the install by URL and use the link from our download server like that:
Hope this helps!
Hope this helps!
- insanojaco
- Topic Author
13 years 5 months ago #4
by insanojaco
Replied by insanojaco on topic [solved] how to install Kunena 1.6.1?
it works! thanks a lotfxstein wrote: This is most likely a limit on your server. Kunena 1.6.1 with all the languages is now over 2MB in size. Some servers have a 2MB limit in place.
Hope this helps!
- Smoothound
- Junior Member
13 years 5 months ago #5
by Smoothound
Replied by Smoothound on topic Error Uploading
Hi
I have several sites all running Joomla 1.5.20+ and all of them have Community Builder v1.2.3
I can install/upgrade K1.6.0 without any problem, but when I try to upgrade to K1.6.1 it fails and all I get is the following error message in Joomla.
Any ideas would be appreciated.
There was an error uploading this file to the server
- Smoothound
- Junior Member
13 years 5 months ago #6
by Smoothound
Should have looked here first.
www.kunena.org/forum/173-k-16-installati...o-install-kunena-161
The same solution works for me.
- visualwaltz
13 years 4 months ago #7
by visualwaltz
Replied by visualwaltz on topic Re: [solved] how to install Kunena 1.6.1?
Ok, so I am having an issue installing the new Kunena 1.6.1
I do have a limited upload on the server (2mb) so I can not install the .zip file
When I tried to do you alternate route (by url: joomlacode.org/gf/download/frsrelease/13...b3858_2010-11-06.zip ) this is the message I get (image below). Is there anything I can do or am I going to have to ask my provider to change the upload max?
13 years 4 months ago #8
Replied by sozzled on topic Re: [solved] how to install Kunena 1.6.1?
I'm sorry to hear that you are experiencing problems with the installation of Kunena.
One alternative method that you might try is to unzip the installation kit on your PC and upload (via FTP) the contents to a folder on your website (and then use the second installation option).
The following user(s) said Thank You: visualwaltz
- visualwaltz
13 years 4 months ago #9
by visualwaltz
Ok solved, I had tried uploading the extracted files through the ftp client before but I guess I just entered the directory wrong before, it worked this time. Thanks
Time to create page: 0.371 seconds
