Kunena 6.4.8 Released
Question [solved] where are the languages in kunena 1.6 (joomla 1.5.20)?
15 years 3 months ago #64883 by bredchic
true. It's the same problem.
15 years 3 months ago - 15 years 3 months ago #64885 by jeff_j_dunlap
xillibit wrote: You need to install Joomla! core language for spanish or others languages that you want use, else the kunena language will be not installed.
I can't say why the following files were not installed even after reinstalling but this is how I manually resolved my issue: :cheer:
In this directory (choose your own language of course):
..\language\es-ES
add these files (choose your own language of course):
es-ES.com_kunena.ini
es-ES.com_kunena.tpl_default.ini
es-ES.com_kunena.tpl_example.ini
The files can be extracted manually from the Kunena 1.6 compressed files.
Your Kunena front end will be in the language of your choice.
P.S. It may be that I had problems because I upgraded my site from K1.5 to K1.6, just guessing though.
Last edit: 15 years 3 months ago by jeff_j_dunlap.
The following user(s) said Thank You: bloque9
15 years 3 months ago - 15 years 3 months ago #64922 by bredchic
Ok, I found this to copmletely remove kunena: www.kunena.com/forum/139-solved-or-prior...how-to-remove-kunena
and I did it.
I reinstalled it (the only one option was: "install kunena 1.6") but nothing, always english only.
I'm going to try with xillibit' solution but I'm not sure it'll work.
The problem is that of I follow the suggestion
I find only:
it-IT.com_kunena.ini
it-IT.com_kunena.xml
and there's no translation inside.
Last edit: 15 years 3 months ago by bredchic.
15 years 3 months ago - 15 years 3 months ago #64925 by jeff_j_dunlap
bredchic wrote: Ok, I found this to copmletely remove kunena: www.kunena.com/forum/139-solved-or-prior...how-to-remove-kunena
and I did it.
I find only:
I tried Killbits solution about 3 times and it did not work for me unfortunately. That is the reason that I manually copied the files over myself.
I looked at the installation and found the files you mentioned above. Maybe the other two ini files that are included in the Spanish version are not required, just guessing of course. Try it and if it doesn't work, you really have nothing to lose.
15 years 3 months ago - 15 years 3 months ago #64927 by jeff_j_dunlap
bredchic wrote: and there's no translation inside.
I opened up the file and this is what I saw:
COM_KUNENA_POLL_STATS_NAME="Sondaggio"
COM_KUNENA_ONLINE="Adesso online"
COM_KUNENA_OFFLINE="Offline"
COM_KUNENA_FORUM_INFORMATION="Info Forum"
COM_KUNENA_GO_TO_CATEGORY="Vai alla categoria"
COM_KUNENA_YOU_ARE_HERE="Tu sei quì"
COM_KUNENA_FORUM_HEADER="Header forum"
COM_KUNENA_GLOBAL_SETTINGS="Settaggi globali"
COM_KUNENA_A_GEN_NEWCHAR="NUOVO"
COM_KUNENA_BAN_EDIT="Edita ban"
COM_KUNENA_BAN_NEW="Nuovo ban"
COM_KUNENA_BAN_BANUSER="Ban utente"
...etc
Looks Italian to me :P
15 years 3 months ago - 15 years 3 months ago #64929 by bredchic
yes.Fortunately there's a sort of Italian hero who did it. I'm asking him how to install that staff.
www.operatoresociosanitario.net/forum/20...na-16-italiano#28638
ciao!
Uh, I saw now your answer... maybe you're right. Ok, I try to copy the files in every folder where there is somethins similar. Than I'll let you know.
Time to create page: 0.311 seconds
