Question [SOLVED] Site completely down after installing RC2...
16 years 2 months ago #61934 by sozzled
cowboysdude wrote: OK after trial and error if I take out the lastest post module that is all that is required and all works!!
Was that the old "latest post" module used for K 1.5?
16 years 2 months ago #62244 by cowboysdude
Correct Sir!!
I didn't just disable it before I put K16Rc2 this time. I uninstalled it totally!
I backup my site.
Installed Rc2
Downloaded the correct Lastest Post Module and installed that
All is working GREAT now.
PLEASE readers be advised that you really need to read. I didn't, my own fault but Thanks to Sozzle all is well.
BEFORE upgrading always follow this rule: Backup..backup...backup... Read, follow the instructions.
Always know that although this team has done an outstanding job they cannot predict every problem that may arise. Secret: Don't panic!! Remember.. backup...backup...backup!! Come back search the forum to see if anyone else has had the same issues, if not ask your question and it will be answered. I have found this to be one of the best supported programs I have ever used, and all this comes amazingly FREE!!
Thank you again for all your help.. You are wise :)
The following user(s) said Thank You: fxstein, sozzled
