Question [SOLVED] Site completely down after installing RC2...
16 years 2 months ago - 16 years 2 months ago #60101 by cowboysdude
After I installed RC2 my site is completely blank. THANK GOD I have a backup. I wouldn't advise anyone installing this right now. Here goes another hour of wasted time...
Last edit: 16 years 2 months ago by fxstein.
16 years 2 months ago #60108 by sozzled
Thank you for your feedback. Did you want any help working through the issues, to understand why you had problems, or do you just want us to make a note of your opinions?
16 years 2 months ago - 16 years 2 months ago #60150 by cowboysdude
It would be awesome to figure out why.. I installed it on my test server without a problem and it's still running... the ONLY thing I can think of that my test server doesn't have his sh404sef running...
Other than that they are identical. I will try to activate sh404sef and try it on the test server.. I just can't imagine it being anything else.
I do like the look and actions of the new 1.6 though... it's looking GREAT!
Last edit: 16 years 2 months ago by cowboysdude.
16 years 2 months ago - 16 years 2 months ago #60170 by sozzled
Thanks for your continuing interest. :)
As you would be aware, if you have been closely following the various discussions over the last couple of months since K 1.6 was first made available to the general public, K 1.6 is substantially different to everything else that has preceded it. It is because of the significant differences in the way it works - in the way that it's been designed to work - that now brings many other issues into play that weren't previously involved. In order to assist you, and others, here's is my quick checklist of things that I would need to look at before I could consider upgrading an existing FB 1.0.5 RC2/K 1.0.x/K 1.5.x website to K 1.6 RC2:
  1. Does my server environment meet the minimum technical requirements to run K 1.6?
  2. Do I have any "legacy" software? I'm not only talking about software that requires J 1.5 sites to be running in legacy mode , I'm also talking about any add-on that was designed to be run on Fireboard, K 1.0 or K 1.5 like the old "latest posts" module or the discussbot plugin , for example.
  3. Do I have any other software integrated with Kunena at the present time, that needs to be updated? If you are using any of Community Builder , Jomsocial , uddeIM then you need to be aware of the need to update your software before you upgrade Kunena. Apparently there are a few issues for users of sh404SEF , too. These are important: that's why we have dedicated categories for issues with these products.
  4. K 1.6 is dependent on Mootools 1.2.4. This dependency may cause problems if people are using Joomla site templates that are not "Mootools 1.2-compatible". If you are not sure then you should contact the developers of your site template and ask them the question. If the results of your enquiries (or testing on a test site) show that you will have a Mootools issue with your template then you have a choice to make: stay with the version of Kunena and the Joomla site template that you've got or change the site template in order to move forward.
  5. Previous versions of Kunena have been more tolerant of database inconsistencies or, perhaps I should say, in the past you may not have noticed any problems because your database was created the way it was. K 1.6 exposes some of these database issues in ways that none of us could have foreseen. It might be necessary to review your database, it might be necessary to change the database collation method , for example.
  6. Last, but not least, there are all the other issues from left-field that no-one (even with the best crystal-ball vision) could possibly have foreseen; these are the "gotchas". For those things there's really only one solution: test K 1.6 on a site that mirrors, exactly, the conditions of your production site so that you avoid the disappointment that a failed upgrade might bring.
If I've omitted something from this list I hope someone will bring it to our attention.
16 years 2 months ago #60197 by cowboysdude
Just had one of those ahhhhhh moments LOL NOT GOOD for me anyway...
I have Sh404sef turned OFF on the test site...
I have also upgraded mootools on the test site to 1.2 .. [there's a site with the information on it as to how to accomplish this that I don't think I need to post here]
and I am not running a latest post module on the test site that I am running on the production site at the moment.. interesting...
SO all-in-all my test DOES NOT mirror my production site.. interesting... and I will reset my test site with a backup of my production site so I can mirror them.
Thank you!!
16 years 2 months ago #61912 by cowboysdude
OK after trial and error if I take out the lastest post module that is all that is required and all works!!
I made a backup of my site and installed it on another computer, took out the Lastest Post module and installed the New Kunena 1.6Rc2 over Kunena that was already there. I used the Migrate function. Emptied my cache in the joomla backend and BINGO... it's on.
Mine seems to be playing nicely with SHS404sef so no problem there.
Many Thanks and if anyone has similar problems please refer to this post and read what was written. Simple problem, simple solution.
Thanks a HUGE bunch again!
