Question [Resolved] Upgrading to 1.6.5 "not possible to delete xxx.php"
PHP 5.2.11
re: recent request to upgrade Kunena to 1.6.5 from 1.5.4
when trying to upload & Install I get the following:
"It was not possible to copy the selected file.
JInstaller::install: Failed to copy file: /home/xxxxx/public_html/tmp/install_4e99854bb5e80/api.php to /home/xxxxx/public_html/administrator/components/com_kunena/api.php
It was not possible to delete the selected file.: 'COPYRIGHT.php'
It was not possible to delete the selected file.: 'CHANGELOG.php'
It was not possible to delete the selected file.: 'router.php'
It was not possible to delete the selected file.: 'kunena.php'
found the files in the C-panel all set to 0777
Can't remove them "permission denied"
(No idea what FTP is, if that's going to be relevant)
Any direction greatly apprecited. Many thanks.
Any attempts to install 1.6.5 or even 1.7 Fail with:
JFTP::store: Bad response
JInstaller::install: Failed to copy file: /home/xxxxx/public_html/tmp/install_4e9b5c2d0b464/api.php to /home/xxxxx/public_html/administrator/components/com_kunena/api.php
JFTP::delete: Bad response
Restored site to earlier date: No change
Forum is practically empty, no issues with re-starting from scratch (Linked with Community builder)
Have contact with Web Site initiator, but priority is way down the list ... may be better to wait ?
try Install from URL: joomlacode.org/gf/download/frsrelease/15...b5135_2011-08-29.zip
regards 810
Unable to create destination
further down...
Warning: strpos() [function.strpos]: Offset not contained in string in /home/xxxxx/public_html/libraries/joomla/filesystem/archive/zip.php on line 325
Sorry ... feeling stupid now
backend-help-system info- Directory Permissions
check that all maps are green (Writable)
regards 810
also checked files listed in the report and they are set to 0777.
As mentioned, the forum (Currently broken & off line) has so few posts, I could wipe the lot without an issue.
But the system won't even allow me to do that.
Have access to CPanel, MyPHP, and site Admin.
If none of these enable me to remove, delete and re-install the latest Rev, I will endevour to contact my Site developer and get back up the priority list.
(My issue... I'm learning, with too much access and maybe too little knowlege)
I have not been able to resolve this issue no matter what I try.
I have un-installed Ver: 1.5.4
and whatever I try to install after this, I just get:
JInstaller::install: Failed to copy file: /home/xxxxx/public_html/tmp/install_4ede705bacf8c/com_kunena_v1.7.0_b5135_2011-08-29[1]/api.php to /home/xxxxx/public_html/administrator/components/com_kunena/api.php
I have gone to the C-Panel and deleted the files listed.
I've even deleted any folders referencing Com_Kunena under Administration/Components/ and Public_html/Components/
Still no use, and whenever I revisit the C_Panel all the additional files that I deleted are back again dated with the original install date of 2009
and I can't find api.php anywhere.
I don't need any details or reference from the orig set up, but I can't even start from scratch. All permissions are OK and writeable.
Last chance or no forum ... its just annoying me now.
It seems, from your last message, that you are trying to install K 1.7.0. Please don't use that version. K 1.7.1 has been available for nearly one month.
I would not be waiting 2 months for an answer, if this was my website. I would be doing everything possible to resolve the problem as soon as possible or (as you say) go elsewhere and look for a different solution.
It takes less than one hour to create a Joomla website and less than 2 minutes to install Kunena and, in 99% of all cases, if you follow the recommended approach, everything works without having to make a single change to anything. But, like all good buildings, if the foundations are bad your site will crash. I strongly recommend that you very carefully read K 1.6 and K 1.7 Upgrade Guide ... and I hope that some of this information helps you.
