Kunena 6.4.13 Released
Question [Resolved] Upgrading to 1.6.5 "not possible to delete xxx.php"
14 years 9 months ago #109087 by WCMCC
Joomla Ver: 1.5.23
PHP 5.2.11
re: recent request to upgrade Kunena to 1.6.5 from 1.5.4
when trying to upload & Install I get the following:
"It was not possible to copy the selected file.
JInstaller::install: Failed to copy file: /home/xxxxx/public_html/tmp/install_4e99854bb5e80/api.php to /home/xxxxx/public_html/administrator/components/com_kunena/api.php
It was not possible to delete the selected file.: 'COPYRIGHT.php'
It was not possible to delete the selected file.: 'CHANGELOG.php'
It was not possible to delete the selected file.: 'router.php'
It was not possible to delete the selected file.: 'kunena.php'
found the files in the C-panel all set to 0777
Can't remove them "permission denied"
(No idea what FTP is, if that's going to be relevant)
Any direction greatly apprecited. Many thanks.
14 years 9 months ago #109140 by Matias
Try to uninstall and install again. That usually fixes permission issues like this (all distribution files get deleted).
14 years 9 months ago #109181 by WCMCC
Un-installed 1.5.4
Any attempts to install 1.6.5 or even 1.7 Fail with:
JFTP::store: Bad response
JInstaller::install: Failed to copy file: /home/xxxxx/public_html/tmp/install_4e9b5c2d0b464/api.php to /home/xxxxx/public_html/administrator/components/com_kunena/api.php
JFTP::delete: Bad response
Restored site to earlier date: No change
Forum is practically empty, no issues with re-starting from scratch (Linked with Community builder)
Have contact with Web Site initiator, but priority is way down the list ... may be better to wait ?
14 years 9 months ago #109183 by 810
14 years 9 months ago #109186 by WCMCC
JFolder::create: Infinite loop detected
Unable to create destination
further down...
Warning: strpos() [function.strpos]: Offset not contained in string in /home/xxxxx/public_html/libraries/joomla/filesystem/archive/zip.php on line 325
Sorry ... feeling stupid now :(
14 years 9 months ago #109188 by 810
please check dir permissions:
backend-help-system info- Directory Permissions
check that all maps are green (Writable)
regards 810
Time to create page: 0.284 seconds
