Important database problem after upgrade to 1.6.3
That's good to hear. At this point we should close the topic as far as the "database problem" is concerned.rodster wrote: now its working ...
Yes, I've already talked about this earlier.rodster wrote: ... BUT.....still buggy? when i click on post it returns me to the index page.
It's really easy to upgrade Kunena from K 1.5.13 to K 1.6.3 (it takes about 2 minutes) but it may take some people several hours (or days) to prepare their website before that perform that 2-minute activity. If people don't do the preparation they can encounter a lot of problems ... and this is an example of a few of those of problems that people may encounter.sozzled wrote: Your Kunena category links do not seem to be working at all. This is probably caused by a conflict in your Joomla menu. I suggest that you need to rebuild your Joomla menus again (see the "trash-burn-build" technique that we've talked about before here).
(1) Incompatible modules
(2) Out-of-date Joomla and legacy mode
(3) Javascript library conflicts
(4) Joomla menu issues
It must be either a plugin or a module, but the only way to find out what is either to disable all of them one by one or search "DROP TEMPORARY" from your files..
