Important database problem after upgrade to 1.6.3
15 years 7 months ago #93013 by rodster
I just uograded Kunena to version 16.3 therefore i had 1.513 now i cannot acces the forum
It gives me a error
500 - JDatabaseMySQL::query: 1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'IF EXISTS' at line 1 SQL=DROP TEMPORARY TABLE tmp IF EXISTS;
Before this upgrade my forum was workin well.
15 years 7 months ago #93020 by rodster
UPDATE: downgraded to 1.6.2 same error
15 years 7 months ago - 15 years 7 months ago #93022 by sozzled
Can you please post your K 1.6 configuration report.
Did you read the K 1.6 upgrade guide ?
Last edit: 15 years 7 months ago by sozzled.
15 years 7 months ago #93025 by rodster
yes i have read the guide and it was clear to me.
These are my configurations.
Also if i keep using 1.6.3 my jomsocial templates /profiles will get messed up.
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Enabled |
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 3M
Joomla default template details : gk_yourflash | author: Robert Gavick - GavickPro | version: 1.0 | creationdate: 30/11/2008
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 2.2.0) | UddeIm: Disabled or not installed
Modules: Kunena Latest: Enabled (Version : 1.0.47) | Kunena Stats: Disabled or not installed | Kunena Login: Disabled or not installed
15 years 7 months ago #93026 by rodster
? i don't have Joomla 1.6! i use 1.520!! and i allready wa susing K1.5.13 so i wanted to upgrade KUNENA to the latest. and that gives me database error right now :angry:
15 years 7 months ago - 15 years 7 months ago #93027 by sozzled
What should have also been clear is that modules developed for older versions of Kunena will not work in K 1.6. The so-called "kunena latest" plugin (that you have installed) was never officially part of the Kunena project and it does not work with K 1.6. Please uninstall that module.
Please read what I have written about using legacy mode . If you want to use legacy mode you will probably have problems.
You may have other problems, too, with the Gavick template but we can't be sure until you get your forum back online.
Time to create page: 0.146 seconds
