- Thank you received: 2534
To get started please see
K 1.6 & K 1.7 Installation Guide
in our
Documentation Wiki
Question Upgrade from 1.6.1 to 1.6.3 failed
15 years 1 month ago #92281
by rich
Replied by rich on topic Aw: Upgrade from 1.6.1 to 1.6.3 failed
I use always a trick, when is a blank page. Maybe it works also for you.
Remove the "go=next" from the browser adress > click "Enter" > and "Next"
15 years 3 weeks ago #93000
by Yxos
/Yxos, Kunena Translator, da-DK.
Overvej at abonnere på kategorien www.kunena.org/forum/48-Danish
Replied by Yxos on topic Re: Aw: Upgrade from 1.6.1 to 1.6.3 failed
That's worth a try indeed!
Just came back from easter holiday... Im gonna try your tip when returning to work on tuesday...
15 years 2 weeks ago #93242
by Yxos
Dead end, unfortunately. There was no such URL that could be amended like you said. I tried a few combinations but without deep knowledge about what parameters to use and how... Its diffucult.
If I can't make it complete the upgrade, I have no other choice but to remove to component and re-install Kunena...
15 years 2 weeks ago #93251
Replied by sozzled on topic Re: Upgrade from 1.6.1 to 1.6.3 failed
Theoretically, you should be able to uninstall K 1.6 and you will not lose anything (i.e. you will not lose your configuration settings or your forum messages). Theoretically, you should then be able to install K 1.6.3 after that ... theoretically. I'll keep my fingers crossed for you.
15 years 2 weeks ago #93257
by Yxos
Replied by Yxos on topic Re: Upgrade from 1.6.1 to 1.6.3 failed
Good idea indeed. Unfortunately it didn't work.
I could uninstall Kunena allright, and I could see it disappear from the list of installed components.
But upon install, the same thing happened. I got the screen where I could select between 3 options; the ones I mentioned before. I chose the first, the green "Upgrade" and again I got the blank screen...
15 years 2 weeks ago #93279
by xillibit
Replied by xillibit on topic Re: Upgrade from 1.6.1 to 1.6.3 failed
Do you have tried to enable debug mode in Joomla! configuration panel to see there is behind the blank page ?
Do you have look in your php or apache log ?
