Question kunena problems after migration from fireboard - please help me
but i'm a little bit ignorant about this kind of changes....
please can you give me a detailed help?
thank you so much!!
if i click on recent topics in debug mode it appear on my screen:
500 - JDatabaseMySQL::query: 1054 - Unknown column 'm.moved' in 'where clause' SQL=Select COUNT(DISTINCT t.thread) FROM jos_kunena_messages AS t INNER JOIN jos_kunena_messages AS m ON m.id=t.thread WHERE m.moved='0' AND m.hold IN (0,1,2,3) AND m.catid IN (8,9,10,11,12,13,14) AND t.hold IN (0,1,2,3) AND t.moved=0 AND t.catid IN (8,9,10,11,12,13,14) AND t.time>'1298317098'
My suggestion is to
(1) Trash and delete all menu links and menu items that refer to Kunena on your website;
(2) Use the Create Menu facility in the Kunena control panel.
500 - JDatabaseMySQL::query: 1054 - Unknown column 'm.moved' in 'where clause' SQL=SELECT m.*, mm.hold AS topichold, mm.locked AS topiclocked, c.locked AS catlocked, t.message, c.name AS catname, c.parent AS catparent, c.pub_access, c.review, c.class_sfx, p.id AS poll_id, c.allow_anonymous, c.post_anonymous, c.allow_polls FROM jos_kunena_messages AS m INNER JOIN jos_kunena_categories AS c ON c.id=m.catid AND c.published INNER JOIN jos_kunena_messages AS mm ON mm.id=m.thread AND mm.moved=0 INNER JOIN jos_kunena_messages_text AS t ON t.mesid=m.id LEFT JOIN jos_kunena_polls AS p ON m.id=p.threadid WHERE m.id='736' AND m.moved=0 LIMIT 0, 1
Please attend to these two matters and then post an updated configuration report if you are still getting errors.
The HTTP 500 error that you mentioned seems to be referring to a Kunena poll. Can we try to keep things simple and let's not try to use advanced features, like polls, until we have worked through the other, more important, problems that you are having. To diagnose HTTP 500 errors, you need to enable Joomla debug mode, Kunena debug mode and look at the Apache error log. This can be quite challenging for beginner users of Joomla.
i tried to remigrate all with the migrator plugin from joomla 1.0 to jommla 1.5.22 nothing to do...same problems same situation....please help me!!!
