Question kunena problems after migration from fireboard - please help me
15 years 8 months ago - 15 years 8 months ago #90051 by mattiaclz
hi my name is Matt is the first time I write on this forum will expose my big problem
after the migration of my joomla website from joomla 1.0 to 1.5.22 and migrated the form part from FireBoard to kunena 1.63
I have the following problems:
when i'm in the homepage of the kunena forum and ina recent topics page of kunena appears (In italian):
kunena internal error:Enable debug Mode....
Kunena Errore interno: Abilita la modalità Dubug Mode per riportare il problema nel forum di www.kunena.org
if I reply to a topic when I press enter to publish the response, this error appear on my screen:
* Kunena Errore interno: Abilita la modalità Dubug Mode per riportare il problema nel forum di www.kunena.org .
* -load-: E' stato richiesto un ID messaggio non valido. (Id messag not valid)
non so che fare vi allefgo la configurazione attuale
I do not know what to do I attach the current configuration
my website www.conigliotravel.it
htaccess: Missing | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 10M
Joomla default template details : yoo_crystal | author: | version: | creationdate:
Last edit: 15 years 8 months ago by sozzled. Reason: Reveal K 1.6 configuration report in message
15 years 8 months ago - 15 years 8 months ago #90077 by xillibit
Please enable debug mode in Kunena configuration panel, to see what's happen.
In your mainmenu, please keep only one item pointing to kunena
Last edit: 15 years 8 months ago by xillibit.
15 years 8 months ago #90080 by mattiaclz
ok i try immediatly many thanks!!! bye
15 years 8 months ago - 15 years 8 months ago #90082 by mattiaclz
nothing is changed....
with debug appear on my screen:
Notice: Undefined property: stdClass::$moved in components/com_kunena/template/default/threads/flat.php on line 56
wath I have to do? please help me...
this is the file with error at line 56
Last edit: 15 years 8 months ago by mattiaclz.
15 years 8 months ago - 15 years 8 months ago #90084 by mattiaclz
File Attachment:
File Name: flat.zip
File Size:3.15 KB
this is the file php with probably the error
15 years 8 months ago - 15 years 8 months ago #90086 by sozzled
You have an "undefined" menu link. This is what you need to fix. See Customised Menus for more guidance.
I also recommend that you read Search Engine Optimisaton (SEO) in the Wiki; this will help a lot!
Time to create page: 0.162 seconds
