Kunena 7.0.8 Released
Question Kunena Upgrade 1.0.11 to 1.6.3
15 years 5 months ago #86194 by CSpaced
Thanks for the info, its much appreciated.
15 years 5 months ago #86443 by CSpaced
I have succesfully upgraded Joomla to 1.5, and have a working copy of Kunena 1.0.11 installed with all of the users and the migrated database functioning correctly.
To tackle the upgrade of Kunena, should I attempt it incrementally (i.e. 1.0 to 1.5, then to 1.6) or should I just try to upgrade straight to 1.6?
Thanks.
15 years 5 months ago #86453 by Matias
I would go straight to Kunena 1.6.3 -- I even test upgrading large database from your version to the latest as I accidentally have backup from it. :)
15 years 5 months ago - 15 years 5 months ago #86471 by CSpaced
Thanks for the reply.
I tried to run the upgrade, but ran into an sql syntax problem, it was using "type=myisam" instead of "engine=myisam". I encountered this problem during the joomla 1.5 installation, and edited the install sql file to the new syntax.
My question is where to find the file referenced in the sql error that is still using "type=myisam"?
I did a search on the forums, other people have had this problem, but there dosen't appear to be any solutions posted.
Thanks in advance.
Last edit: 15 years 5 months ago by CSpaced.
15 years 5 months ago #86495 by xillibit
What mysql version do you have ?
15 years 5 months ago #86517 by CSpaced
xillibit wrote: Hello,
Hi There,
My local server is MySQL V5.5.8
Thanks.
Time to create page: 0.320 seconds
