- Thank you received: 1
Question K 1.6.2 Issues on clean Joomla install.
Clean install of Joomla 1.5.22.
Dir permissions all set, php 5.2.10, sql 5.0.77, 64m mem set in php.
During the install, I click the green button, browser hangs for a second then kicks a 500 error.
Wiped the Joomla install multiple times to try upgrading from rc2, installing from web, installing from dir, same results.
When trying to view the site from the frontend I could see that the install got as far as taking the forum offline but turning debug on does not seem to give me any clues on where I went wrong.
Rc2 still seems to work, guess ill stick with that for now.
If there were any changes that need to be made to the php.ini file, where can I find what needs to be added/changed? (This is the only thing I have not messed with on this attempt since I did all that for rc2).
So, where is does K 1.6 RC2 come into the situation? Is there some way that you can show your K 1.6 configuration report?
I think you have some old software running on this so-called "clean" Joomla installation that is making a mess of the upgrade. That's just my guess, though.
I did not attempt an 'upgrade' until after multiple failures on a fresh, no componants, no modules, no NOTHING install of Joomla. Default template, ONLY installation that occurred after Joomla was K1.6.2.
My 'so-called' clean install has NOTHING else installed. Would love to hear what other sofware could be making a mess of it since the entire directory was empty except for my .htaccess file before Joomla. The word 'wiped' was used in my explanation BEFORE I mentioned any upgrade attempts.
To clarify, Only Joomla was installed, K1.6.2 failed during the install process with a 500 error. I attempted multiple more times, reinstalling joomla after wiping EVERYTHING, same 500. I THEN proceeded to start over, deleted the db, deleted the entire Joomla install, re-installed Joomla from scratch, installed 1.6 rc2 with ZERo problems, attmepted to upgrade to 1.6.2 only to have it fail with a 500 error.
Sorry for the confusion.
It does not appear to be linked in the wiki, only referenced and I do not have a Joomla Dev forum act to download it.
Mentioned here but not made available:
docs.kunena.org/index.php/How_to_report_configuration_settings
Can you do that for us?
Why are you messing around with K 1.6 RC2 on a clean installation of J! 1.5.22? I understand that you were having problems installing K 1.6.2 but I do not understand the problems that you have. You say that you got a HTTP 500 internal server error. Did you get any other messages? You might need to enable Joomla debug mode, try again to install K 1.6.2, to see if you get any other messages apart from just "HTTP 500".
From the sounds of it, you might not have enough of "something" on your website to install K 1.6.2. Have you looked at other topics to see the kinds of issues that people have encountered installing K 1.6.2 and the ways that other people resolved their problems? Maybe there is something there that will help you.
sozzled wrote: I am totally confused. I know how to use the JTS-post assistant either. All that I would like to see is what happens when you press the button you should see on your Kunena Control Panel:
NO.
Every K 1.6.2 link returns a blank page with a 500 error.
I was not 'messing around' with K 1.6rc2, I used it as a test to narrow down where I am having issues. Since 1.6 rc2 Installs FINE and works FINE, I thought that might help me better diagnose the situation. If that button exists in rc2 will that suffice If i reinstall joomla, reinstall K1.6rc2, press that button and report back here?
Joomla debug isnt much help when a page isnt being rendered at all either.
In further attempts to fix my blank page issue w/ K1.6.2, I increased the php memory limit to 128 (up from 64) and increased my upload file size to 8 9up from 2). I also updated php to version 5.2.17. Re-installed Joomla, reinstalled k1.6.2, but still, blank page, 500error.
I will attempt to fix my problem so I can click that button tho.
