To get started please see
K 1.6 & K 1.7 Installation Guide
in our
Documentation Wiki
Question Fresh install of 1.6.1 failing -- code is showing
15 years 5 months ago #76563
by Toolie
Fresh install of 1.6.1 failing -- code is showing was created by Toolie
Hi there, I read through the Kunena readme, but missed the step that said I should not have installed Artof User before I installed Kunena. I uninstalled Artof User and tried reinstalling Kunena 1.6.1 in my freshly installed Joomla site. The installation appears to work, but when I try to select anything of Kunena from the Component menu in Joomla, I see what appears to be an installation screen with multiple steps, but instead of text, there are just language strings like:
COM_KUNENA_INSTALL_STEP_PREPARE
COM_KUNENA_BUTTON_NEXT
When I click on the button text to try to complete the installation, I get an HTTP 500 error and can't get any further. I've attached a partial screen capture so you can see what I'm seeing.
Help! What's going on here?? Did having Artof User installed first cause this problem? I can uninstall and reinstall, but can't get past the installation non-functioning screen.
Please advise, time is NOT on my side...
Thanks!
Thanks!
15 years 5 months ago #76567
by xillibit
Replied by xillibit on topic Re: Fresh install of 1.6.1 failing -- code is showing
What is default language on your Joomla! installation ?
Which is the step where the installation is failing ?
15 years 5 months ago #76878
by Toolie
Replied by Toolie on topic Re: Fresh install of 1.6.1 failing -- code is showing
You ask a good question; when I was trying to install, it was en-GB. I have just installed en-US (since I live in the USA), which installed successfully. I tried installing Kunena again, and it's still giving me the same error. Here are the steps I followed:
1. Uploaded the Kunena files, unzipped, to a folder on my server.
2. Went to the Extensions | Intall/Uninstall menu, and installed Kunena from the "Install from Directory" box.
3. Kunena appeared as a choice in the Components menu. Selecting any of the Kunena submenu items brings up the screen in the attached #1 image below -- what appears to be the start of the Kunena installation steps.
4. If I click on the "com_kunena_install_install" green button in that screen shot, then I see the attached #2 image below. Clicking the "Next" button brings up the HTTP 500 error screen, and I can't get any further.
Does this help?
Does this help?
15 years 5 months ago - 15 years 5 months ago #77012
by xillibit
Can-you give me a super admin access on your site like that i can make a try ?
Last edit: 15 years 5 months ago by xillibit.
15 years 5 months ago #77158
by Toolie
Yes, I can give you access, but I'd prefer to use my GoToMeeting account. Please see the private message for details.
15 years 4 months ago #78077
by Toolie
To be thorough, I tried completely deleting my Joomla installation and reinstalled it over again. Next I installed the en-US language pack, then tried installing Kunena 1.6. I'm getting exactly the same errors as before.
I noticed that with other plugins and components, my Joomla installation didn't seem to know how to unzip files; I ended up unzipping the files on my hard drive and uploading the uncompressed files to my TMP folder for installation. I see that Kunena has ZIP files in subdirectories; would it help if I unzipped ADMIN, MEDIA, and SITE zip files in the ARCHIVE directory along with the en-GB language archive THEN uploaded it to my TMP directory for installation?
Please advise, and thank you.
Toolie
Toolie
Time to create page: 0.259 seconds
