Im not sure how to find the configuration report setting... I must admit im not too experienced in the SQL section.
I checked that the DB were using is mysql 4.1 which I can see now is bad, and probably the reason for the problem. Sorry for having wasted your time with a problem that was my fault and not the boards.
Can I perhaps mark all the stuff in the 4.1 DB and export it, then import it in the 5.1 DB?
Or will it take alot more work to get that done?
Thanks a lot for a wonderful job in Creating the forum and constantly updating it.
I figured that was the way - having some timeout problems when trying to import again - so I started to doubt if it was the right way to do it. But thanks alot for clearing that up - and thanks again for the great piece of software!
