Question Another blank page during upgrade 1.5.12->1.6RC1
15 years 8 months ago #59368 by Matias
DOMDocument is needed for almost all new PHP5 software as it's the only decent way to parse XML files. PHP has supported it for over 5 years and it is installed by default in every PHP environment. So someone has turned it off.
We can add check for this into the installer, though..
15 years 8 months ago #59450 by huxley
So, how can I see if my server has turned DOMDocument off? Via phpinfo()?
Thanks,
H.
15 years 8 months ago #59487 by Matias
Yes, it is not listed in there if it's turned of.
15 years 8 months ago #59505 by huxley
Unlucky I can't find any "DOMDocument" in Php Info, and in Configure Command I read also: '--disable-dom'
Is this the problem?
Thanks,
H.
15 years 8 months ago #60251 by Matias
Yes, because of Kunena doesn't run without DOM extension. :(
Time to create page: 0.209 seconds
