Question Another blank page during upgrade 1.5.12->1.6RC1
15 years 8 months ago - 15 years 8 months ago #59231 by huxley
Hi all!
I want to upgrade my 1.5.12 Kunena forum to 1.6 version!
On the first step of !.6RC1 installer I choose option: Migrate Kunena 1.5.12, but I see a blank page and give errors like this (after I have to reinstall old Kunena 1.5 to see again forum):
Fatal error: Class 'DOMDocument' not found in /var/www/MYSITE/administrator/components/com_kunena/install/schema.php on line 192
Before migrating I have uninstalled all old (latest kunena module and discuss bot plug).
Ah, if i try to uninstall Kunena 1.5.12 I see another blank page and errors like this:
Warning: require_once(/var/www/MYSITE/administrator/components/com_kunena/api.php) [function.require-once]: failed to open stream: No such file or directory in /var/www/MYSITE/administrator/components/com_kunena/install.script.php on line 27 Fatal error: require_once() [function.require]: Failed opening required '/var/www/MYSITE/administrator/components/com_kunena/api.php' (include_path='.:/usr/share/pear:/usr/share/php') in /var/www/MYSITE/administrator/components/com_kunena/install.script.php on line 27
Any help please to migrate and upgrade to Kunena 1.6?
Thanks,
H!
Last edit: 15 years 8 months ago by huxley.
15 years 8 months ago - 15 years 8 months ago #59251 by xillibit
There is a similar problem described here : www.kunena.com/forum/173-k-16-installati...it=10&start=20#58886
Thanks,
S!
This issue doesn't happens when you try to uninstall Kunena 1.6
Last edit: 15 years 8 months ago by xillibit.
15 years 8 months ago - 15 years 8 months ago #59257 by huxley
So to migrate and upgrade to K 1.6 I have to enable (install) DOMDocument php5 extension? But how? I have not php access on the server, I have only ftp access! Are there a way to resolve this issue? :unsure:
Thanks,
H!
15 years 8 months ago #59259 by xillibit
The best way is to ask to your host if he can enable the DOMDocument php5 extension, if he doens't want to do that the only solution is to choose an another host, i know that is annoying for some users but if you want run k1.6 it's the only solution.
15 years 8 months ago #59317 by huxley
xillibit wrote: The best way is to ask to your host if he can enable the DOMDocument php5 extension, if he doens't want to do that the only solution is to choose an another host, i know that is annoying for some users but if you want run k1.6 it's the only solution.
OMG, thanks for the response, but I think I rest with K 1.5.x :dry:
Thanks,
H.
15 years 8 months ago #59346 by xillibit
Your hoster doesn't want to enable DOMDocument php5 extension ?
Time to create page: 0.323 seconds
