Question Migration from old Fireboard 1.0.3 to Kunena
14 years 7 months ago #119372 by magostoni
Hello guys,
I have a customer with an old Joomla 1.0 site and Fireboard 1.0.3 component;
I would need to upgrade it to kunena and I searched a little in the forum; it seems I could do an upgrade from Fireboard 1.0.4 to Kunena 1.5
SoI would like to have some more info:
1) is it true?
2) where I can fine the upgrade to fireboard 1.0.4?
3) could I upgrade directly from Fireboard to Kunena 1.6?
Regards,
14 years 7 months ago #119376 by sozzled
G'day, magostoni, and welcome to Kunena.
You should have no difficulty upgrading Fireboard from version 1.0.3 to version 1.0.5rc. The information on what you need to do in that area is given in Migrating from Fireboard 1.0.3 to Kunena in Joomla 1.5
The next steps are, however, more complicated. After upgrading to Fireboard 1.0.5RC you need to migrate your Joomla website from J! 1.0 to J! 1.5. You may find this helpful: extensions.joomla.org/extensions/migrati...oomla-migration/3895
After moving to J! 1.5 you can then upgrade from FB 1.0.5RC directly to K 1.7.2 (assuming of course, you meet the technical requirements and other matters discussed in K 1.6 and K 1.7 Upgrade Guide . Alternatively, it may be better to leave the old site behind and start anew with J! 2.5.1 and K 1.7.2 instead.
See my 'blog article I want to migrate my forum to Kunena ...
14 years 4 months ago - 14 years 4 months ago #124102 by royc
I'm in a similar position to Magostoni, except that I don't have the expertise to do the migration myself, even having read the instructions and sequence.
We have a website on Joomla 1.0 with Fireboard 1.0.3, the plan is to build a new site in Wordpress and migrate the Fireboard forum to it, because the forum has lots of ongoing threads. Wordpress rather than Joomla, because the front end is reportedly easier for the layman to use and Joomla is pretty hard work.
We need to find someone who knows how to do that, any idea where one would look for a contractor apart from Elance, which doesn't seem big on Fireboard-Kunena skills?
Many thanks,
Roy
Last edit: 14 years 4 months ago by royc.
14 years 4 months ago #124105 by sozzled
G'day, royc, and welcome to Kunena.
I can only say "Good luck" to you in your venture. Both Kunena and Fireboard were written for Joomla and neither of them will work in Wordpress. Sorry but your plan will not succeed. You need to find an alternative forum that works in Wordpress and find some other way of preserving your FB stuff.
14 years 3 months ago #126471 by magostoni
I'm experimenting the procedure and I'm quite at the end with good results, but I would need another info about table structure in Kunena.
Consider I upgraded to kunena 1.7 on J1.5; so does the tables of kunena 1.7 on J1.5 are the same of kunena 1.7 on J2.5?
I'm asking so because I would like to move definitively to J2.5 and so my idea was:
- made the first part of the migration you explained me and obtain J1.5 with K1.7
- install a new fresh J2.5 site
- move by phpmyadmin the kunena tables from J1.5 to J2.5
regards,
Matteo
14 years 3 months ago #126492 by xillibit
The tables of Kunena 1.7 are exactly the same on Joomla 1.5 or 2.5.
If you move the tables like this, you need to don't forgot de move the users too.
