Question Kunena 1.7 not showing on webpage nor controls on backend. Help!
14 years 6 months ago #111095 by sozzled
Would it be possible to post your configuration report, please? I don't know what is the cause of your problem but it sounds like you've got bigger problems than what you've described. What are you expecting, instead, to be in that "small white space" that seems to be at the bottom of your homepage? In other words, what have you assigned to occupy that position?
14 years 6 months ago #111096 by sbbritt
Hi Sozzled
Since I am working on the server (and not locally) where could I access a config report? I have attached a file of the system info and the config for Joomla and a screenshot of the admin interface. In the meanwhile I will contact the server folks and see if they can obtain one and email it to me.
In that small white space is where I have Kunena pointed to appear on the homepage. Does it need to be on an internal page alone?
Susan
14 years 6 months ago - 14 years 6 months ago #111097 by sozzled
14 years 6 months ago #111098 by sbbritt
Sorry syntax error in file name for this one. Here it is.
14 years 6 months ago #111099 by sbbritt
Double phooey. Here it is again in .txt
14 years 6 months ago - 14 years 6 months ago #111100 by sozzled
That doesn't help us much. See your PM.
EDIT: An update on the status of this issue is that the site is currently offline because of matters that require the assistance of the webhosting provider. When those matters have been taken care of we may be able to move forward to see what's going on.
The following user(s) said Thank You: sbbritt
Time to create page: 0.230 seconds
