Question Topic headers (h2?) text squashed
Hi There,
I am using the default Kunena template, with Rocketthemes Panacea template. All up-to-date versions. I haven't yet been able to solve my squashed h2 titles. No other headers/titles are affected. I have tried disabling build titles span in Panacea, without no effect. I haven't been able to change it by adding letter spacing in css.
Any ideas please?
Many thanks,
Config settings as follows:
Legacy mode: Disabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
This message contains confidential informationhtaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 200M | Max file upload: 100M
Joomla default template details : rt_panacea_j16 | author: RocketTheme, LLC | version: 1.6.0 | creationdate: April 21, 2011
board_title Profit From Science board_offline 0 board_ofset 0.00 offline_message <h2>The Forum is currently offline for maintenance.</h2>
<div>Check back soon!</div>enablerss 1 enablepdf 1 threads_per_page 20 messages_per_page 6 messages_per_page_search 15 showhistory 1 historylimit 6 shownew 1 jmambot 0 disemoticons 1 template default showannouncement 1 avataroncat 0 catimagepath category_images/ showchildcaticon 1 annmodid 62 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 0 showuserstats 0 showkarma 1 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 1 allowfavorites 1 maxsubject 50 maxsig 300 regonly 1 changename 0 pubwrite 0 floodprotection 0 mailmod 0 mailadmin 0 captcha 0 mailfull 1 allowavatar 1 allowavatarupload 1 allowavatargallery 1 avatarquality 65 avatarsize 2048 allowimageupload 0 allowimageregupload 1 imageheight 800 imagewidth 800 imagesize 150 allowfileupload 0 allowfileregupload 1 filetypes txt,rtf,pdf,zip,tar.gz,tgz,tar.bz2 filesize 120 showranking 1 rankimages 1 avatar_src fb fb_profile fb pm_component no userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 0 userlist_username 1 userlist_posts 1 userlist_karma 0 userlist_email 0 userlist_usertype 1 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 0 latestcategory 0 showstats 0 showwhoisonline 1 showgenstats 0 showpopuserstats 0 popusercount 5 showpopsubjectstats 1 popsubjectcount 5 usernamechange 0 rules_infb 1 rules_cid 1 help_infb 1 help_cid 1 showspoilertag 0 showvideotag 0 showebaytag 0 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 0 autoembedebay 0 ebaylanguagecode en-us fbsessiontimeout 1800 highlightcode 0 rss_type topic rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 rss_cache 900 fbdefaultpage recent default_sort asc alphauserpointsnumchars 0 sef 1 sefcats 1 sefutf8 0 showimgforguest 1 showfileforguest 1 pollnboptions 4 pollallowvoteone 1 pollenabled 0 poppollscount 5 showpoppollstats 0 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 50 ordering_system mesid post_dateformat ago post_dateformat_hover datetime hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 50 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access communitybuilder integration_login communitybuilder integration_avatar communitybuilder integration_profile communitybuilder integration_private uddeim integration_activity communitybuilder boxghostmessage 0 userdeletetmessage 0 latestcategory_in 1 topicicons 0 onlineusers 1 debug 0 catsautosubscribed 0 showbannedreason 0 version_check 1 showthankyou 1 showpopthankyoustats 0 popthankscount 5 mod_see_deleted 0 bbcode_img_secure text listcat_show_moderators 1 lightbox 1 activity_limit 0 show_list_time 720 show_session_type 0 show_session_starttime 0 userlist_allowed 0 userlist_count_users 1 enable_threaded_layouts 0 category_subscriptions post topic_subscriptions every pubprofile 1
Third-party components: CommunityBuilder: The file doesn't exist comprofilej.xml ! | UddeIm: The file doesn't exist uddeim.j15.xml !
The issue is caused by your Joomla site template (in the way that <H2> text is rendered, and you will find the CSS rule buried in one of your site template CSS files. Using a tool like Firebug for Firefox (you can use other tools, if you like) will identify what rules affect the web content and you can then override those rules with your own. However, without seeing what exactly is causing the text compression, I can't tell you exactly what you need to fix.
Your Joomla site template has the following rule definition:
h1, h2 {
letter-spacing: -2px;
line-height: 1em;
If you want all <H1> and <H2> tags to be squashed together on the whole of your site, then leave this alone, but that's the CSS definition used in your site template (located, in your case, in the folder ../libraries/gantry/css) and I have no idea why it's needed like that. Remove or deactivate the "letter-spacing" rule and your Kunena forum will be OK; something like this will do it:
h1, h2 {
// letter-spacing: -2px;
line-height: 1em;
You also asked me by PM to advise you why your Kunena menu is "invisible". Actually, the menu isn't invisible, it's only that you have not published . It's there but you have not published a link for it (or a module to display it). Easily fixed if you trash-burn-build your current menu links to your Kunena forum or read Customised Menus in the Wiki for the answers.
Alternatively, I could do this job for you (any one a number of people can do this job for you) but, as I will be out-of-town today, it will have to wait for another 24 hours at least before I am available.
Your site also exhibits the well-documented Rockettheme-Kunena "Quote button" partial occlusion issue. See the topic Quote Button - conflict with Rockettheme typography for the illustration of the problem and the answer to it.
As far as any other problems on your site are concerned, please start a new discussion topic for each one. Thank you.
sozzled wrote: }
h1, h2 {
line-height: 1em;
...Your site also exhibits the well-documented Rockettheme-Kunena "Quote button" partial occlusion issue. See the topic Quote Button - conflict with Rockettheme typography for the illustration of the problem and the answer to it.
Many thanks Sozzled. Commented out that code & more a couple of lines below - squashed text sorted. Menus sorted. Quote issue sorted!
You are a most helpful Megabeing.
I have exactly the same problem with text spacing with another rt template.
new.tabletennis.gr/index.php/forum
However I cannot find the css file to fix it.
Thanks,
Denis
