Kunena 7.0.8 Released
Question Background color change effects link colors?
15 years 2 months ago #95309
Replied by sozzled on topic Re: Background color change effects link colors?
Then you might be better off directing your enquiry (about how to use Rocketteme templates) from the developers of that template. After all, you paid for it.
It's quite easy to see what CSS files and rules need to be changed in order to adapt Kunena to your site. I suggest that you consider using a web developer tool (like Firebug ) to help; there's a brief tutorial of Firebug in the Wiki if you're interested. Is there some other way that we might be able to help?
15 years 2 months ago #95310
by xertox
Replied by xertox on topic Re: Background color change effects link colors?
My problem is solved. I was just trying to help Payne because he said he was having a similar issue...
The following user(s) said Thank You: Payne
15 years 2 months ago #95311
Sorry ... and thanks for your help :blush:
15 years 2 months ago #95928
by xertox
Turns out my problem is not solved.
Is there a way to stop the link colors from changing when I edit the header back ground color in Kunena Template Manager?
15 years 2 months ago - 15 years 2 months ago #95929
The link colours are unaffected by the Blue Eagle template options. You have to add your own CSS definitions (which you should add to your Joomla site template CSS file(s)). Firebug is the way to go.
Here's something you might like to experiment with for your own site (but you'll have to change the colours around yourself). Add the following lines to your Joomla site template file:
The above CSS is only an example of some of the things you can add to your Joomla site template - this is what I'm using on a red/beige/black theme.
#Kunena div, li, table, p, td, span, a {
font-family: "Trebuchet MS" !important;
#Kunena div.kthead-title a {
font-size: 19px;
#Kunena a:hover {
text-decoration: underline
#Kunena a:link, #Kunena a:visited, #Kunena a:active, #Kunena a:focus {
background-color: transparent !important;
color: #F36018 !important;
#Kunena .kwho-admin, #Kunena a.kwho-admin {
color: #FF0000 !important;
#Kunena .kwho-globalmoderator, #Kunena a.kwho-globalmoderator {
color: #800000 !important;
#Kunena .kwho-moderator, #Kunena a.kwho-moderator {
color: #0000FF !important;
#Kunena .kwho-user, #Kunena a.kwho-user {
color: #5388B4 !important;
#Kunena .kwho-guest, #Kunena a.kwho-guest {
color: #666666 !important;
#Kunena .kpagination .active {
background-color: #830510;
border-color: #830510;
color: #FFFFFF;
#Kunena .kpagination a {
Last edit: 15 years 2 months ago by sozzled.
15 years 2 months ago - 15 years 2 months ago #95930
by xertox
The link colors are very much effected. Every time I change the Forum Header Background under blue ealge im Kunena Template Manager my link colors take on that exact same color.
Observe... Keep in mind my default link colors are purple like the screen shot I posted initially.
When I change Forum Header Background to #1d1d1d
And if I change Forum Header Background to #FFFFFF
Last edit: 15 years 2 months ago by xertox.
Time to create page: 0.260 seconds
