Merged [Resolved] [Merged topic] Blurred, blurry, fuzzy, text in category headers (text-shadow)
15 years 3 months ago - 15 years 3 months ago #97258 by OliRC
Hi James,
Are you able to use something like Firebug? Or if you happen to be on a Mac, you can enable the developer menu in Safari, to do similar things. This would allow you to pinpoint the file, and indeed the piece of code, which you need to remove/alter.
I didn't take note of exactly what I did because I thought it wouldn't be consisted with other templates.
If you post up a link to your site, or PM it to me, I could take a look and see if I can work it out.
Last edit: 15 years 3 months ago by OliRC.
15 years 3 months ago #97370 by james2581
ok now this is just getting weird. In google chrome its blurry. In Windows Explorer it's perfect.
I don't have firebug, but I saw somewhere google chrome has something similar built in. Where?
The link is www.JameZtown.com but I guess it will only be blurry for some people.
Weird.......
Check out My online community. Once you stop by you will be hooked. www.JameZtown.com
15 years 3 months ago #97387 by 9themestore
Open the www.jameztown.com/templates/siteground-j16-3/css/template.css file and go to about line 200. Delete the line
text-shadow: 1px 1px #FFFFFF;
I hope it work. :)
The following user(s) said Thank You: OliRC
15 years 3 months ago #97417 by OliRC
That looks like it'll do the trick. :cheer:
You could also just change the Hex code if you fancied changing the shadow to a different colour. However, I found on my site that it also change things elsewhere and I couldn't find a colour that would work throughout, so I just removed it.
Also worth noting, if you change to a different template, you may have to change it's template.css file again, but at least you'll know how to do it now.
:woohoo:
15 years 3 months ago - 15 years 3 months ago #97426 by sozzled
james2581 wrote: I don't have firebug, but I saw somewhere google chrome has something similar built in. Where?
Right mouse-click the element on the page that you want to look at, then select Inspect Element from the context menu. You access Firebug the same way in Firefox. In Internet Explorer you have to press F12
Last edit: 15 years 3 months ago by sozzled.
15 years 3 months ago #97457 by james2581
thanks so much, I removed the code "text-shadow:1px 1px #fff;" and it worked great.
Glad I found this board and excited to learn more about this software.
James
Time to create page: 0.233 seconds
