- Thank you received: 1
Merged [Resolved] [Merged topic] Blurred, blurry, fuzzy, text in category headers (text-shadow)
15 years 6 months ago - 14 years 4 months ago #89431
by OliRC
[Resolved] [Merged topic] Blurred, blurry, fuzzy, text in category headers (text-shadow) was created by OliRC
How do I change the shadow colour of the text highlighted in the below screenshot? As you can see, text and shadow colour are both white, giving the blurry eyed look.
I've looked through my template css and can't find anything there. I don't mind adjusting the Kunena template files. That's what I've done in the past, but this time it is evading me.
Thanks.
Thanks.
Last edit: 14 years 4 months ago by sozzled. Reason: Change topic icon
15 years 6 months ago #90104
by OliRC
Replied by OliRC on topic Re: Changing text shadow colour of 'Section' name
Any suggestions, anybody? :dry:
15 years 6 months ago #90107
Replied by sozzled on topic Re: Changing text shadow colour of 'Section' name
Shadowed text is not a standard feature of Kunena. For example, you will not see shadowed text here, at
www.kunena.org
. Do you want to keep shadowed text or would you like to remove it? We have been asked where this shadowed text originates from and, in all cases, it originates from a CSS rule in your Joomla site template.
Most of these kinds of isses can be resolved if you learn to use a web developer's tool like Firebug.
Therefore, to help me understand your question better, do you want to keep the shadowed text (with a different shadow colour perhaps) or do you want to get rid of the shadow completely so that your forum looks something similar to what we have here at this site?
15 years 6 months ago #90109
by OliRC
Thanks Sozzled. It's something that I have managed to change in the past, but as you say, probably by adjusting the template css, which this time around, I can't work out.
Anyway, yes, I'd be happy to remove the shadow altogether.
15 years 6 months ago #90110
by OliRC
Meant to say, programs like Firebug tend not to work on Macs, so not much use for me, unless there is something you can recommend...
15 years 6 months ago #90114
Google Chrome has a built-in developer's tool; I'm unsure about Safari.
Try this topic - it's a little bit different to what you've asked about - Tabs Shadow .
If that doesn't work, can you post the URL of your website, please. We might be able to get a better handle on your problem if we can see the issues for ourselves at first hand. Thanks.
The following user(s) said Thank You: OliRC
Time to create page: 0.262 seconds
