Question special page layout forum
15 years 9 months ago #85172 by Stefan
On my Website I usually have 2 columns, like on the kunena page too.
I wuld now like to have the forum span over the full width of the page, so to say have only one wide column, as it is here in the kunena-forum too.
Where so I have to set which parameter, so that the forum shows up full width?
www.integraleimpulse.de/forum/index.html
15 years 8 months ago #87823 by Stefan
I found a solution myself.
I just made a copy of my template, switched it to one-column and activated thos version only at the kunena-pages! :)
15 years 8 months ago #87825 by gato_de_botas
Stefan, what file did you change to switch your template to one-column? Wich template are you using?
Give me the link to your site, please. I will give a look.
Also see my post (number 7) in the topic bellow:
www.kunena.org/forum/170-k-16-templates-...the-right-side#87809
I found a way to make the forum using the right side, inspecting the page with FIREBUG. What I am trying to figure out is WHAT IS THE HTML FILE that shows on the left side of the firebug screen? I changed this file on the fly in the firebug screen, adjusting some numbers, and the forum got OK. But the problem is that firebug does not show what and where is the html file that shows on the LEFT side of his screen. Only the CSS files that shows on the right side of the firebug's screen has the path.
See my post in the topic, there are the images.
15 years 8 months ago #87827 by Stefan
Hi Gato,
I built my template with Artisteer. It's not very cheap, but does a good job!
My standard template has 2 columns and is used on all of the pages except the fourm: www.integraleimpulse.de
I made a copy of the template (within Artisteer) and switched it to '1 column'. Then I loaded the new template onto the site and activated this new template only for all of th kunena menus. This is the result: www.integraleimpulse.de/forum/index.html
I hope that helps!
15 years 8 months ago #87833 by gato_de_botas
thanks Stefan!
Nice your site!
Artisteer is in my agenda, I will use it very soon to make my templates, but at this moment I have to finish the site I am working on. Adjusting the forum is the last step of a long work, everything else is OK.
Do you have familiarity with Firebug? I am trying to figure out what is the html file that shows on the left side of firebug's screen. On the right side of firebug screen there are the CSS files. Firebug shows the name and paths for the CSS files.
But to make the changes to adjust the forum, I used the LEFT side of firebug screen. There are an HTML code of the page, I made the adjustments on the fly, in real time, but firebug does not show WHAT the html file is! Firebug does not show the name or the path to the html file that shows on his left screen, that is the problem!
I have been searching in the template folder, but could not find the file. It is not the INDEX.PHP file of the template folder.
Do you have firebug installed? Do you know where in firebug I can find the path to the html file that shows on the left side?
15 years 8 months ago #88012 by gato_de_botas
Problem Solved!
There was a blank TEST MODULE at the right position that I forgot about!
I disabled it and Kunena is filling the right border now.
