Question [Merged topic] How to make Kunena template full width?
15 years 11 months ago - 15 years 11 months ago #65199 by FieldRep1
Hey Gang
I'm trying to increase the size of my forum but can't seem to find what I'm doing wrong. I disabled all modules on the sides of the forum page but can't seem to get it changed. I don't think it's the template preventing me from doing this because at one point the size was larger then present.
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Disabled | FTP layer: Disabled |
Third-party components: AlphaUserPoints: Installed (Version : 1.5.4) | CommunityBuilder: Installed (Version : 1.2.1) | Jomsocial: Installed (Version : 1.8.7) | UddeIm: Installed (Version : 1.9)
Last edit: 15 years 11 months ago by sozzled. Reason: Subject edited by moderator - we don't use all caps here
15 years 11 months ago #65200 by FieldRep1
It would be great if there was just a way to get clone of your current forum and ALL its settings. Just thinking out load here.
15 years 11 months ago #65201 by sozzled
Unfortunately as I cannot see your forum - you have only allowed registered users to view it - I can't see the problem for myself. It's my guess that the problem relates to the site template that you're using. Even though this document ( How I can get the full width for Kunena Forum in my site? ) was written for a previous version of Kunena, the ideas are still fairly much the same.
Using Firebug for Firefox will identify the cause of the issue in next-to-no time. At this stage, without seeing what's happening on your site, that's the only general kind of advice I can give. These problems are as unique as there are different Joomla site templates available for users to choose from. If we can't help you better, you should take up your issue with the Joomla template developer from whom you obtained the template.
There is a way to "clone" your site; it's really easy, too. Use a product like Akeeba Backup and your fixed. ;)
The following user(s) said Thank You: FieldRep1
15 years 11 months ago #65394 by severdia
I would have responded sooner if I'd seen your post. :)
Lines around 521 in your template CSS file are the problem. Add these lines to the bottom of your CSS file to resolve the width issue:
#bottomwrap_kun { width:945px !important; } #bottomleftwrap_kun { margin-right:0 !important; width:auto !important; }
15 years 11 months ago #65437 by FieldRep1
I really appreciate the help guys.
15 years 7 months ago #84002 by Frankie4life
Replied by Frankie4life on topic Forum width problem
My forum width just changed on my website today. It is now only about half the size that it was with a blank spot on the right column. Does anyone know how to adjust this back again?
Thanks,
Frankie
Time to create page: 0.293 seconds
