Question IE8 problems
i make forum tab plugin only for registers users
i can make for all if you have troubles with registration
mediaboxAdvanced 1.3.4
(updated December 3rd, 2010) There seem to be some errors in Internet Explorer 8 when using version 1.3.4b. Until I get a chance to test things out and fix the bugs, you may be better off with version 1.2.5, listed under “older versions” – be sure to download all the pieces, as installation needs images as well!
so we will wait for an fix for it.
regards 810
Thanks a lot!
extract the mediaboxAdv.js file to: \components\com_kunena\js\mediaboxadvanced\js
extract the css file (choose white or black) to :components\com_kunena\js\mediaboxadvanced\css and rename the file to: mediaboxAdv.css
then clear your internet cache and try again.
regards 810
No other issue found, thanks a lot!!!!!!!!!!!!!
Any issues with using this older version of Mediaboxadvanced?
